  • Excel has found a problem and needs to close down
    Posted on WSHowardC Comment on the AskWoody Lounge
    Home Forums AskWoody support Productivity software by function MS Excel and spreadsheet help Excel has found a problem and needs to close down
    This topic contains 1 reply, has 2 voices, and was last updated by  zeddy 2 years, 7 months ago.
    • #508424 Reply
      WSHowardC
      I am using office 2013 (64 bit) at work and Windows 10.
      From time to time when I open an Excel file, Excel comes up with a message “Excel has found a problem and needs to close down”
      It has happened to several files that I wanted open lately
      It is rather frustrating and I do not know what is causing this. I have one workbook in xlstart and not sure if this could be the cause or one of my add-ins such as “ASAP” , “Analysis Toolpak-VBA” etc
      It would be appreciated if someone could kindly assist me on how to resolve this problem
    • #1593629 Reply
      zeddy
      Hi Howard
      ..this is a tricky problem to nail down, especially when it happens when you are opening the same file. Excel occasionally seems to need to ‘catch it’s breath’ when opening a file: there are lots of things going on, especially with files that have vba code. Some parts of Excel are ‘impatient’ while other Excel tasks ‘under-the-hood’ are still executing.
      We would need to know whether the file you are working with has auto_open code, or workbook_opencode, (or both)
      zeddy
      • #1593647 Reply
        WSHowardC
        Hi Zeddy
        Thanks for the reply
        It is at the time of manually selecting the file/files to open that Excel shuts down
        None of the files that I need to open has has auto_open code, or workbook_opencode
        Regards
        Howard
    • #1593682 Reply
      Maudibe
      Howard,
      From an IT standpoint, it is far better to just do an Office repair instead of attempting to speculate what may be causing the issue. This is done from the control panel > Add Remove programs. It’s a painless process. Follow the instructions here:
      https://kb.wisc.edu/helpdesk/page.php?id=9344
      HTH,
      Maud
      • #1593761 Reply
        WSHowardC
        Hi Maud
        Will definitely do a repair
        Howard
    • #1593949 Reply
      Lugh
      If you still have a problem Howard, install the 32bit version of Office—that’s the recommended choice unless you have a specific need for x64. See here:
      Choose between the 64-bit or 32-bit version of Office
      Lugh.
    Reply To: Excel has found a problem and needs to close down
