What a mess.If you know of any other problems, please comment on the InfoWorld article!InfoWorld Tech Watch.
[See the full post at: Microsoft’s December patch hangover: KB 3008923 unrepentant; Fixit for some 2553154, 2726958 problems; 3004394 dead; and 3011970 re-issued]
Home » Forums » Newsletter and Homepage topics » Microsoft’s December patch hangover: KB 3008923 unrepentant; Fixit for some 2553154, 2726958 problems; 3004394 dead; and 3011970 re-issued
- This topic has 24 replies, 5 voices, and was last updated 8 years, 4 months ago.
AuthorTopicwoody
ManagerViewing 23 reply threadsAuthorReplies-
Deborah
GuestThe only two updates you mention that effect me are KB2596927 (for Office 2007) and KB3008923 (for IE 11) I am not overly concerned about the IE 11 patch since I use Firefox, but I use my Office applications (especially Word) on a daily basis. What if I simply do not install these two updates at all? I did not install KB3011780 on your recommendation, but it still appears in my update queue. I still have no plans to install it.
Eric
Guest -
Manager -
Manager -
Marty
Guest -
Sam
AskWoody LoungerWoody
I am running Windows 7 on my laptop. The only Patch that I have from your list is KB3008923. The others I have are KB3013126 KB2952664 KB3006121 KB3006625 KB3009736 KB3013410 KB3014406 KB890830. Is it OK to go ahead with the other updates and just hold off on KB3008923 or should I wait until you raise the MS-DEFCON level. -
Erik
Guest -
Yuhong Bao
Guest -
Manager -
Manager -
Manager -
DA
GuestMicrosoft’s KB3025036 is now up to version 9. Woody, have you heard anything more about a proper resolution to the problems with patch KB2553154 for Office 2010 (and related patches for other versions)? We are having headaches with macros/macro buttons working on some PCs but not others.
MIS
GuestMade a comment on an earlier post about updates after a replacement HDD and Windows 7 install – I am guessing to go ahead and skip the December problematic IE 11 app (Office is critical, if it breaks, schoolwork does). So go ahead and wait until maybe Thursday 1/15 2 days after Jan patch tuesday to apply all IE 11 updates?
One last question?
Do you have any resources for Outlook 2013(Desktop Client for Windows)and the problematic Autodiscover when attempting to connect to Exchange Online? – It always fails.
Manager -
Manager -
Charlie
Frank
GuestAfter some careful study I decided to triage KB2726958, KB3008923, KB3008925 and KB3004394 as offered in December for Windows 8.1 64 bit system. I installed the other December patches without incident and have not experienced any discernible issues as of yet. I think KB3004394 will be OK to install as the issues it created seem to surface on Windows 7 and Server 2008 only. However, out of an abundance of caution the four patches noted will not be installed until the confidence level becomes clearer.
Mis
GuestRegarding IE, it hasn’t been updated since 4/2014. the only ones I am offered in Windows update are one from August http://support.microsoft.com/kb/2976627) -it’s on Revision v9
and via Microsoft’s website (IE 11 November Cumulative IE 11 Update….
https://support.microsoft.com/kb/3003057)
It’s on revision v4, but I would need to manually download and install it.The only ones being offered through Windows Update are December’s IE 11 patch (KB3008923)
http://support.microsoft.com/kb/3008923What about any other major issues with patches? Our university blocks Wi-Fi Access if our patches are significantly out of date.
Next month I will have to look into Susan Bradley’s Patch Watch.
Manager -
Marty
Guest -
walker
AskWoody LoungerI posted a reply, however I can’t see where it went through. My question is about KB 2553154 which I installed in error. I have had no problems, however I do not use Excel now. However should I uninstall it to be safe as I may use Excel in the future?
Also all of the other patches were installed without incident, however I have only NOW noted the Defcon 2 warning and am wondering if I should uninstall all of the December patches.
Thank you for the wonderful advice you provide.
Manager -
Manager -
Manager
Viewing 23 reply threads -
AOL changes its web based email
Charlie
3 hours, 26 minutes ago -
Windows 11 Insider Preview build 23471 released to DEV
6 hours ago -
Windows 11 Insider Preview Build 22621.1830 and 22624.1830 released to BETA
6 hours, 2 minutes ago -
Spyboy Defense Evasion Tool Advertised Online
13 hours, 22 minutes ago -
Gigabyte motherboards backdoor
3 hours, 58 minutes ago -
numbering in a table
RopyDavits
18 hours, 25 minutes ago -
LMDE 5 32-bit dual boot on seperatd drives
bassmanzam
16 hours, 34 minutes ago -
Microsoft ends 2017 Surface Book 2 support
My monitors won’t turn on
23 hours, 5 minutes ago -
AMD Software Failed to Launch Because Windows Update Has Replaced the AMD…
Microsoft : New macOS vulnerability, Migraine, could bypass System Integrity…
1 day, 17 hours ago -
Remove One Drive
crudolphy
1 day, 23 hours ago -
11 hours, 17 minutes ago -
How to change “User Account Control:Run as administrator”
DKThompson
2 days, 3 hours ago -
Two monitors, want different “fixed” wallpaper on each one
MauryS
2 days, 10 hours ago -
Microsoft forcing move to Microsoft account?
Tom
2 days, 8 hours ago -
Event 2545 Device Management – Enterprise – Diagnostics – Provider
2 days, 11 hours ago -
QBot malware exploits Windows WordPad EXE to take over
3 days, 6 hours ago -
Laptop powers off during KB5026361 update
dhunter
How to enable Sleep in Shut down menu?
3 days, 8 hours ago -
Beware of Google’s .ZIP domain and password-embedded URLs
9 hours, 31 minutes ago -
Longstanding feature requests, and their status
Mary Branscombe
3 days, 16 hours ago -
Three typing tutors — no more “hunt and peck”
3 days, 15 hours ago -
Is online banking secure?
Bluetooth audio not working on older Lenovo T420 with Win 10
WSmsc0357
2 days, 21 hours ago -
Using wildcards in search and replace
Bob Karrow
4 days, 1 hour ago -
How is Windows XP a security risk?
Curious
16 hours, 24 minutes ago -
Is using VPN a good idea?
3 days, 22 hours ago -
How to prevent/disable Bitlocker Automatic Device Encryption?
4 days, 9 hours ago -
Unexplained aspects of installing the latest update of Office 2021
TonyC
4 days, 9 hours ago
- Three typing tutors — no more “hunt and peck”
- Is online banking secure?
- Are you ready for AI?
- Getting started with winget
- No NumLock key? Problem solved! Here’s the fix.
S | M | T | W | T | F | S |
1 | 2 | 3 | ||||
4 | 5 | 6 | 7 | 8 | 9 | 10 |
25 | 26 | 27 | 28 | 29 | 30 |
