  • need help with wifi and Atheros
    Home Forums Networking – routers, firewalls, network configuration need help with wifi and Atheros
    This topic contains 20 replies, has 4 voices, and was last updated by  qaz 7 years ago.
    • #1771972 Reply
      qaz
      hi
      Ive just got a Asus Eee pc netbook with Atheros client utility. have never used wifi , can anyone help me set it up
      thanx
    • #1818709 Reply
      WSjwitalka
    • #1818710 Reply
      qaz
      thanks but it seems much to general to be helpful….tells u about positioning ur router etc. i really need some assistance with Atheros client utility.
      error msg after running a check says: client adapter not associated to an access point. and. configure radio card ssid and othe properties. i recon it something very simple [when u know how]
      any ideas are welcome
    • #1818711 Reply
      WSruirib
      Maybe this can help:
      http://www.motioncomputing.com/kb/article.aspx?id=10269This seems to be a detailed manual: http://www.yatow.de/out/fck_files/CE-papers/ce-ar5bmb5.pdf
      You need to know the configuration settings for your wireless network: SSID, type of authentication, encryption used, key used. With that, filling in those settings in the utility should be easy.
    • #1818712 Reply
      qaz
      thanks i will look.
      if it helps this was apparently working ok before i get this asus EEEpc.
      in most locations there are several strong signals, i assume that the absence of a “key” symbol opposite some networks means i can access it without a password ?.
      is this notebook in some way locked to using Atheros or can i use Windows or another program
      edit: have tryed to follow the setup intructions but stuck on “What encrytion is used” i bet if i were to ask the staff working in the cafe providing the wifi they wouldnt know
      im assuming thar SSID is the number/word supplyed by the person offering wifi access
      • #1818724 Reply
        MrJimPhelps
        thanks i will look.
        The absense of the key symbol means that the network in question is not encrypted. It doesn’t necessarily mean that no password is required.
        But unless you have permission to log onto a wireless network, you shouldn’t try to log onto it.
        There’s not really any setup required; you simply find the network you want to log onto in the list of available wireless networks; then you connect to it, putting in whatever password is required.
        That’s all there is to it.
        The SSID is the name of the network that you see listed in the list of available wireless networks.
    • #1818713 Reply
      WSruirib
      How did you get the atheros software? I would presume wireless hardware you have is an Atheros adapter. In Windows 7 you have usually have the option to let windows configure and control the adapter.
    • #1818714 Reply
      qaz
      have xp and arthos came with the eee pc notebook
      am wondering if this notebook in some way locked to using Atheros or can i use Windows or another program
    • #1818717 Reply
      qaz
      i dont know about the adaptor , theres nothing attached to the computer
    • #1818718 Reply
      WSruirib
      That just means that the adapter is integrated, which makes total sense, as all recent laptops need to suppport wireless networking.
      • #1818721 Reply
        qaz
        i have an asus eee pc 2g surf net-book running xp . Atheros client utility basically works, the machine connects to a wifi network ok as long as there is no encryption [set to set none as opposed to wpa/wpa2 or another one], But when someone in a wifi enabled building gives me a key/password to use i apparently i don’t enter it in the right place, [the ssid1 field is filled in automatically]
        Another thing is that although under the security tab i have tried the first 3 encryption types [said to be the most used ones here in uk] i still cant decide which one to use in a given situation and the staff offering the wifi certainly dont know. Is there a way to tell?. If i decide to try wpa/wpa2 [the first one] then i have to also select a wpa/wpa2 type from the drop down menu ……the configurations are too many to try.
        the instructions are no help that i can see and am wanting to take this machine on holiday next week, with ability to connect so any assistance will be appreciated
        Or can direct me to a relevant forum as i havent found one yet that covered this software
        thanx
    • #1818720 Reply
      qaz
      can anyone help with the client utility? the machine connects ok as long as there is no encryption [set to set none as opposed to wpa/wpa2 or another one] , But when someone gives me a key/password to use i apparently i don’t enter it in the right place, [the sii field id filled in automatically]
      thanx
    • #1818723 Reply
      WSruirib
      You need to know whether they are using WPA or WPA2. For both, the encryption options are AES or TKIP. If you don’t know which one is it, then you need to try until you connect. The settings will vary according to the network and you need to choose the ones for the specific network you will be using. I don’t think anyone here can tell you much more than this…
      • #1818730 Reply
        qaz
        thanks last 2 posts
        re: “You need to know whether they are using WPA or WPA2.” are u saying that these are the only 2 that are used even though there’s a longer list? anyway, even if they are after i select WPA or WPA2 i then can select WPA or WPA2eap Type from drop down menu starting with Leap then eap-tls.
        i cant find any reference to AES or TKIP.
    • #1818733 Reply
      WSruirib
      I don’t know the specifics of your adapter and its client. I guess you need to try, because the configuration will vary with each network.
      Sometimes using older software and hardware has such issues. Since Windows 7 (probably Vista too), connection to a wireless network is just easier, because the OS just asks you the key and deals with the security choices on its own.
      Did you check to see if they have updated versions of the client?
    • #1818737 Reply
      qaz
      my version is old and ive found the new one but it only list it as being Applicable to 4 makes of computer….so what do i do?
    • #1818738 Reply
      qaz
      yes its old but the newer version is apparently for 4 makes of machine…..does this mean it will not match the adapter in my machine
    • #1818741 Reply
      qaz
      maybe i will abandon atheros and us windows built in tool…anyone know what its short comings are?
      • #1818743 Reply
        WSruirib
        In your case, I would probably try. It may be slightly less featured, but show allow you access to the wireless networking, which is really what matters.
    • #1818742 Reply
      WSjwitalka
      If you are referring to the wireless utility loaded in the startup tab of MSConfig, I would definitely disable it. You should only need the wireless driver. I always disable vendor supplied wireless utilities and use Microsoft’s wireless instead.
      Jerry
    • #1818756 Reply
      qaz
      only use the xp built in tool now but its still not right…..ongoing problems, i dont think this forum is the place to tackle it so thanks to all who have helped
    Reply To: need help with wifi and Atheros
