MS-DEFCON 2:
New AskWoody Knowledge Base article: How to rip audio CDs, reliably and at highest quality
Home › Forums › AskWoody blog › New AskWoody Knowledge Base article: How to rip audio CDs, reliably and at highest quality
- This topic has 10 replies, 8 voices, and was last updated 6 months, 1 week ago.
Viewing 6 reply threads-
AuthorPosts
July 9, 2020 at 7:38 am #2278860
Da Boss@NetDef has come up with a tour de force – the most thorough guide I’ve seen to ripping audio CDs. He takes you through every step, in meticulous deta
[See the full post at: New AskWoody Knowledge Base article: How to rip audio CDs, reliably and at highest quality] -
July 9, 2020 at 11:25 am #2278897
AskWoody MVPI’m still using Windows Media Player, it’s already installed. I set my destination folder years ago. Just open Windows Media Player, insert a CD, set ripping presets to .flac, rip automatically and eject after ripping. It preserves all the metadata as well as the album art. A bunch of CD’s can be ripped in fairly short order.
Create a fresh drive image before making system changes/Windows updates, in case you need to start over!"When you're troubleshooting, start with the simple and proceed to the complex."—M.O. Johns"Experience is what you get when you're looking for something else."—Sir Thomas Robert Deware-
July 9, 2020 at 1:01 pm #2278937
NetDef
AskWoody_MVPWMP is very good (most of the time) at automatically finding and applying metadata for our libraries. I used it for a while too. One feature where WMP especially used to excel was in finding and applying Album cover art to display while playing. (A topic by the way that I will be addressing “soon(tm)” in the KB article.)
And I still think WMP may be the best tool for many people, with the least amount of hassle.
I presented an alternate method because what WMP lacks is fine tuned control of how the structure of your libraries are created and managed — and a properly maintained structure makes your library MUCH more useful when you want to play your library on other devices other than your PC.
Also, you know, choice. 🙂
But . . . The number of misses in recent years, where entirely wrong metadata was applied in WMP has risen quite a bit. Now this hasn’t been a problem for some who’s library looks like a top-40 list. But for those who’s music tastes run into the eclectic range, and especially in classical and world music, it’s a real problem. Worse, once it makes a mistake, its very hard to fix it for that album in WMP. (Personal experience.)
On a side note, WMP online metadata services have been discontinued on older platforms. See https://www.thurrott.com/windows/198508/microsoft-retiring-a-windows-media-player-feature-on-older-windows-versions for information.
~ Group "Weekend" ~
This reply was modified 6 months, 1 week ago by
NetDef.
July 9, 2020 at 1:20 pm #2278941
NetDef
AskWoody_MVPOh, for those reading this thread, BBearren mentions using WMP to encode (rip) CD’s to FLAC.
This is not natively supported in WMP on a new install of Windows (any version.)
But you can easily add FLAC playback and encoding support to WMP. Get this from the actual source (not some third party) at https://xiph.org/dshow/
You’re looking for the download link on that that page for
Windows 32/64-bit Installer: opencodecs_0.85.17777.exe
Once you’ve installed it, FLAC will show up in the WMP rip options. And WMP will play FLAC just fine.
I’m posting this because so very many of the codec downloads you will see in a search for FLAC codec / encoder / decoder are for malware sites.
~ Group "Weekend" ~
July 10, 2020 at 7:22 am #2279100
AskWoody MVPOh, for those reading this thread, BBearren mentions using WMP to encode (rip) CD’s to FLAC. This is not natively supported in WMP on a new install of Windows (any version.)
I don’t do new/clean installs (any version), I only do updates/upgrades. So even in Windows 10 2004, WMP still has FLAC natively supported as an optional file format. I didn’t have to do a thing.
July 10, 2020 at 7:45 am #2279110
AskWoody MVPI presented an alternate method because what WMP lacks is fine tuned control of how the structure of your libraries are created and managed — and a properly maintained structure makes your library MUCH more useful when you want to play your library on other devices other than your PC.
My default music library is structured (on its dedicated hard drive) by artist/album. As you know, WMP can present it to me by artist, by album or by genre.
As for playing music from other devices, I have a large playlist copied to my phone’s SD card and to some thumbnail-sized thumb drives; one can put a lot of music on a 16GB drive no bigger than my thumbnail. It’s completely unobtrusive when plugged in, there’s just a little bump visible. The radio in my truck will accept bluetooth, aux cable, and has a USB port. The playlist is rather large and my preference is to have playback shuffled.
My platform is Windows 10 2004, and I haven’t encountered any misses yet.
July 9, 2020 at 1:18 pm #2278940
Elly
AskWoody MVPThere are many possible apps for ripping music. @NetDef uses foobar2000, an open source, free app, to do the walk through for ripping CDs… multiple screen shots, with the settings and options highlighted, so it is very easy to follow the instructions.
Over the years I’ve ripped CDs on multiple machines, through multiple apps, with multiple formats. @NetDef gives instructions that result in quality FLAC files, for archiving your music collection… and then has easy steps for converting those to phone/device ready MP3 files.
For those that have juggled getting their favorite music all in one place, in the same format, @NetDef‘s article provides clarity about just how to do that.
Why use FLAC for archiving?
We use it because it’s widely compatible with most advanced music players, and because it’s a true bit for bit copy that can be safely used if we need to convert to other formats.
Rather than ending with my eyes glazed with complexity, I was able to rip a CD (one from a local group, that doesn’t have its music on line, but that is special to me)… I never used FLAC before, but I want my music collection to last as long as I do. Thanks, @NetDef, as this is a great article!
And, once your music collection is archived- back it up!
July 9, 2020 at 2:44 pm #2278966
AskWoody MVPExcellent write-up from @NetDef from the Windows perspective.
For those of you who use Linux, check out Asunder it’s available in Ubuntu/Debian Repo’s and encompasses the process of ripping CD’sSaves audio tracks as:
WAV, MP3, Ogg Vorbis, FLAC, Opus, Wavpack, Musepack, AAC, and Monkey’s audio files.
Uses online CDDB to name and tag each track.
Creates M3U playlists
Can encode to multiple formats in one session
Simultaneous rip and encode
Allows for each track to be by a different artist
Doesn’t require a specific linux desktop environment
No problem can be solved from the same level of consciousness that created Pebcak
July 9, 2020 at 8:11 pm #2279035
rontpxz81
AskWoody LoungerI use CDex stiil at it’s highest settings 320 kpbs- good enough for me. Plus it has extensive settings, and can make a good copy of some damaged discs with it’s extreme settings.
July 10, 2020 at 12:04 am #2279049
July 10, 2020 at 9:20 am #2279129
AuthorPosts
Viewing 6 reply threads -
Search The Lounge
Recent Replies
Kirsty on Understanding Section 230
37 minutes agoOscarCP on Forum Alphabetical Order bbCode List
38 minutes agoCorfe on Understanding Section 230
38 minutes agoKirsty on Minor Lounge Button Tweaks
57 minutes agoOscarCP on Shaun the Sheep, etc: animated shows in Netflix to watch while self-isolating.
1 hour, 9 minutes agoMoonshine on Forum Alphabetical Order bbCode List
1 hour, 16 minutes agorje81849 on Latest Updates, nothing but feature update showing
1 hour, 34 minutes agoKirsty on Forum Alphabetical Order bbCode List
1 hour, 39 minutes agojoep517 on Sysinternals Suite Update
1 hour, 40 minutes agob on Minor Lounge Button Tweaks
1 hour, 40 minutes agoKirsty on Minor Lounge Button Tweaks
1 hour, 53 minutes agoPKCano on Updates paused but not?
2 hours, 12 minutes agoPKCano on Security update for Secure Boot DBX can be skipped (KB4535680)
2 hours, 18 minutes agob on A Zero-day Windows 10 bug corrupts your hard drive on seeing this file’s icon
2 hours, 24 minutes agoPFC on Time to Cleanup Partitions
2 hours, 42 minutes agoSusan Bradley on Security update for Secure Boot DBX can be skipped (KB4535680)
2 hours, 48 minutes agoMicrofix on Security update for Secure Boot DBX can be skipped (KB4535680)
2 hours, 52 minutes agoNetDef on Security update for Secure Boot DBX can be skipped (KB4535680)
3 hours, 9 minutes agoPKCano on Forum Alphabetical Order bbCode List
3 hours, 12 minutes agoAlex5723 on Windows 10 Latest Patch: KB 4598242
3 hours, 23 minutes agoanonymous on What Is the Latest Stable Version of Windows 10?
3 hours, 24 minutes agoAlex5723 on January 2021 updates are here
3 hours, 35 minutes agoAlex5723 on The MacBook Pro pre-2016 is back
3 hours, 47 minutes agoanonymous on What Is the Latest Stable Version of Windows 10?
3 hours, 49 minutes agoanonymous on WiFi Security Alerts after moving from 1909 to 2004
3 hours, 50 minutes agoanonymous on Windows 10 Latest Patch: KB 4598242
3 hours, 51 minutes agob on What Is the Latest Stable Version of Windows 10?
4 hours, 16 minutes agoWCHS on Minor Lounge Button Tweaks
4 hours, 47 minutes agoMoonshine on Forum Alphabetical Order bbCode List
5 hours, 1 minute agoPaul T on Forum Alphabetical Order bbCode List
5 hours, 44 minutes ago
KB4598242 fails to install, in rollback loop 2021-01 cum upate
2 hours, 13 minutes ago
2 hours, 19 minutes ago
Copying Folder Names Into Excel
10 hours, 1 minute ago
The iPhone Companion
9 hours, 56 minutes ago
Apple Tips : 9 tips to take control of your privacy on iPhone
10 hours, 13 minutes ago
Internet drops briefly
10 hours, 21 minutes ago
Windows 7 ESU year two oddities
14 hours, 46 minutes ago
Color Rendering in PowerPoint 2019 Export to Video Function
23 hours, 4 minutes ago
OOMA vs MagicJack
1 day ago
Want 7GB of extra disk space?
1 day, 7 hours ago
Windows 10X and its purpose
1 day, 10 hours ago
Neither Exchange nor GMail will connect
1 day, 2 hours ago
Tweaking spreadsheet data
11 hours, 52 minutes ago
Firefox Browser Replacement – Opera
2 days, 1 hour ago
Windows 10 Insider Preview build 20292 released to DEV Channel
1 day, 2 hours ago
orange screen white lines HP all in one touchscreen
2 days ago
Adobe Flash Not working for School test
20 hours, 45 minutes ago
Apple to block sideloading iOS apps on M1
2 days, 13 hours ago
Mouse not always loading properly in Win 8.1
1 day, 1 hour ago
Resurrection Remix on the Moto G7 Play is a winner
2 days, 18 hours ago
Something Overriding My Group Policy Settings
20 hours, 15 minutes ago
Install some updates in queue but not all
2 days, 21 hours ago
Remove Windows 10 file security warning, WordPad
2 days, 23 hours ago
Text Box, Bullets, Graphics and Animations
3 days, 1 hour ago
- Security update for Secure Boot DBX can be skipped (KB4535680)
- Windows 7 ESU year two oddities
- Attention partners: Microsoft really is coming for your clients this time
- January 2021 updates are here
- MS-DEFCON 2 – Get ready for January updates
- What do you want?
- Time to adapt while acknowledging the past
- Stop paying $200 a year for your Internet cable modem
