MS-DEFCON 4:
There are isolated problems with current patches, but they are well-known and documented on this site.
PNY Flash Drive Problem
Home › Forums › AskWoody support › PC hardware › Questions: How to troubleshoot hardware problems › PNY Flash Drive Problem
- This topic has 9 replies, 7 voices, and was last updated 1 month, 2 weeks ago.
Viewing 8 reply threads-
AuthorPosts
January 18, 2021 at 1:39 pm #2335591
WSjcgc50
AskWoody LoungerI’ve been trying to view the files on a PNY flash drive. I’ve tried with three different Win 10 computers. It doesn’t show up in windows explorer. I can see it in device mgr. It was listed as some Innostor Flash Drive. I tried uninstalling the device and was able to access it once afterward but didn’t have an external source to copy the files to at hand. Haven’t been able to repeat that again.
Here is what I see when I access its properties. Any suggestions?
January 18, 2021 at 1:56 pm #2335597
geekdom
AskWoody PlusIt’s likely the flash drive is corrupt.
Do you have another flash drive available?
Do you have the flash drive contents available on another drive or device?
On Hiatus {with backup and coffee}
offline▸ Win10Pro 2004.19041.572 x64 i3-3220 RAM8GB HDD Firefox83.0b3 WindowsDefender TRV=1909 WuMgr
online▸ Win10Pro 20H2.19042.804 x64 i5-9400 RAM16GB HDD Firefox86.0 WindowsDefender TRV=20H2 WuMgr -
January 18, 2021 at 2:31 pm #2335619
WSjcgc50
AskWoody Lounger-
January 18, 2021 at 4:24 pm #2335676
Rick Corbett
AskWoody_MVPHowever, I would like to rescue these files.
Others with the same problem have apparently been able to recover their files using this SP USB Flash Drive Recovery software.
(I’ve downloaded it – just in case – but haven’t yet had cause to use it.)
Here’s where I found an example of someone who used it… and their apparent hardware fix (post #7) to resolve an issue with the Innostor chip in PNY flash disks.
January 19, 2021 at 3:53 am #2335801
AskWoody PlusTry rescuing the data with the free Portable Recuva app.
Use ‘deep scan’-
This reply was modified 1 month, 2 weeks ago by
Alex5723.
January 18, 2021 at 6:21 pm #2335706
WSjcgc50
GuestI agree that it is likely corrupt. I do have other drives that work. However, I would like to rescue these files. They wouldn’t be a critical loss.
Thanks for the suggestion. I downloaded and tried the software. It sees the drive but when I start the process it gives me an error message and suggests that I unplug the USB and plug it back and it still doesn’t work.
I’ve previously uninstalled the device on all three windows machines. That worked the first time and I wish I had tried to copy the data at that point. I can see the device in disk management but it simply says there’s no media. I’ve tried changing the drive letter as well.
It may be time to pitch this drive and move on.
January 19, 2021 at 9:56 am #2335867
WSjcgc50
AskWoody LoungerTry rescuing the data with the free Portable Recuva app.
Use ‘deep scan’-
Alex5723.
I downloaded the Windows version of the app and the problem is that none of these programs can see the drive because it doesn’t show in windows explorer.
January 19, 2021 at 12:02 pm #2335893
GuestYou could try Photorec, it is free , but it may also not see the drive. https://www.cgsecurity.org/wiki/PhotoRec_Step_By_Step
January 20, 2021 at 12:49 pm #2336232
EP
AskWoody_MVPlooks like your PNY flash drive is pretty much dead & is non-recoverable
get a new flash drive from a different manufacturer like either SanDisk or KingstonI had that happen to be once with an old PNY 16gb usb drive a few years ago where none of my PCs can no longer recognize it after using that flash drive for several years
January 20, 2021 at 1:18 pm #2336244
mn–
AskWoody LoungerEvery now and then it’s possible to read one of these in Linux. Other times that doesn’t work either.
… and then there’s that one failure mode where you can make Linux keep retrying in raw mode and get something at a rate of about 2 to 8 Mbytes per day, which is just no fun at all… and then it turns out that you got zeroes from that particular block that should’ve held the actually useful data. BTDT, was an ancient 128 MB drive.
January 20, 2021 at 1:26 pm #2336248
AskWoody MVPah yes, that has happened to me in the past with a toshiba 16Gb flashdrive. Windows refused to see it, tried it in GNU linux and wow, things were there long enough to get the data copied (unfortunately not all) as the flash device had some sort of corruption.
I didn’t try anything else, took the dataloss hit and just disposed of the flashdrive at the local recycling centre along with other electronic waste.
January 20, 2021 at 3:07 pm #2336267
geekdom
AskWoody PlusFor what it’s worth, this method has been recommended with failing hard drives, but I don’t know if it will work with flash drives. Place the flash drive in the refrigerator a few hours, then try to read from it. I never tried placing any hardware in the refrigerator.
AuthorPosts
Viewing 8 reply threads -
Recent Replies
Rick Corbett on Automatic virus definition updates for Defender
20 minutes agoAlex5723 on Is this the best science fiction show ever?
36 minutes agoBob99 on Firefox opening tabs spontaneously
54 minutes agoRick Corbett on February Update 20H2 – Telemetry changes
55 minutes agoT on Tasks for the weekend March 6 – check your logins
1 hour, Just nowJohn on ‘System’ reports high CPU
1 hour, 9 minutes agoJohn on ‘System’ reports high CPU
1 hour, 11 minutes agoanonymous on Tasks for the weekend March 6 – check your logins
1 hour, 21 minutes agoT on Tasks for the weekend March 6 – check your logins
1 hour, 24 minutes agoanonymous on Tasks for the weekend March 6 – check your logins
2 hours, 13 minutes agoOscarCP on Is this the best science fiction show ever?
2 hours, 14 minutes agoT on Standalone installer script for Windows 7 ESU, regardless the license
2 hours, 26 minutes agoOscarCP on Is this the best science fiction show ever?
2 hours, 27 minutes agoanonymous on Plus member bonus – Exchange security issue
2 hours, 34 minutes agoSusan Bradley on Introducing a new deployment service for driver and firmware updates
4 hours, 3 minutes agob on Tasks for the weekend March 6 – check your logins
4 hours, 17 minutes agoSusan Bradley on Tasks for the weekend March 6 – check your logins
4 hours, 28 minutes agoanonymous on Tasks for the weekend March 6 – check your logins
4 hours, 32 minutes agob on Why do “print to PDF” articles contain 2 copies of each image?
4 hours, 38 minutes agoMoonshine on Windows Reader View creates duplicate images
4 hours, 43 minutes agoFred on Introducing a new deployment service for driver and firmware updates
4 hours, 46 minutes agoMoonshine on Why do “print to PDF” articles contain 2 copies of each image?
4 hours, 49 minutes agowavy on Is this the best science fiction show ever?
5 hours, 13 minutes agoECWS on Startup Impact Not Measured
6 hours, 5 minutes agoLiz C. on Why do “print to PDF” articles contain 2 copies of each image?
6 hours, 7 minutes agoanonymous on Automatic virus definition updates for Defender
6 hours, 8 minutes agoanonymous on Another Win10 Update and Metered Connection Question
6 hours, 9 minutes agoanonymous on ‘System’ reports high CPU
6 hours, 10 minutes agoanonymous on ‘System’ reports high CPU
6 hours, 11 minutes agoSeff on MS-DEFCON 4 – February updates trigger few issues
6 hours, 13 minutes ago
“Accellion” supply-chain attacks steal banks, private and government data.
53 minutes ago
Windows 10 Monthly Update Known Issue Rollback
1 hour, 22 minutes ago
55 minutes ago
4 hours, 44 minutes ago
4 hours, 4 minutes ago
How to uninstall McAfee
7 hours, 51 minutes ago
Song for an IT experience
11 hours, 24 minutes ago
21 minutes ago
1 hour ago
4 hours, 39 minutes ago
ESU 2021 activation “error: product not found”
13 hours, 48 minutes ago
2 hours, 35 minutes ago
Encrypted DNS (DoH) now on Win 10 – but better than dnscrypt-proxy?
16 hours, 32 minutes ago
Download DVD disk
16 hours, 10 minutes ago
Windows 10 Home update: wushowhide.diagcab won’t download
10 hours, 16 minutes ago
Macro app for Windows 10?
1 day, 6 hours ago
Where are we as respects 20H2 Feature Upgrade?
1 day, 9 hours ago
upgrading method
1 day, 15 hours ago
At Least 30,000 U.S. Organizations Newly Hacked Via Microsoft’s Email Software
12 hours, 11 minutes ago
Telemetry
1 day, 16 hours ago
Microsoft Security Response Center
1 day, 21 hours ago
SRU and SRUDB
2 days, 4 hours ago
AI generated play
23 hours, 20 minutes ago
Free-form database wanted
15 hours, 3 minutes ago
LinkedIn will stop collecting IDFA data on iOS
1 day, 3 hours ago
56 minutes ago
KB4603002 – Feb 2021 Patch for .Net Framework.
3 days, 6 hours ago
reboot takes forever, normal boot from off is quick
2 days, 5 hours ago
- Tasks for the weekend March 6 – check your logins
- Plus member bonus – Exchange security issue
- March 2021 Office non-Security Updates are now available
- Do you still patch on premises Exchange servers?
- “Stuttering” glitch on a brand-new PC
- Here’s looking at you, kid: the child-cam scam
- The best things in life are copyrighted
- Using Microsoft OneDrive on your Android device
