  • Screen Saver and power settings quit
    Home Forums AskWoody support Windows Windows 10 Questions: Win10 Screen Saver and power settings quit
    Viewing 5 reply threads
      • #2370144
        jgosney
        A few months ago, my screen saver and power settings .i.e  screen power and PC sleep have completely quit working – despite Windows settings saying they are on.  This a desktop (Dell) unit.  Any clues where to look?
      • #2370429
        doriel
        Stopped working you mean, that PC does not go to sleep mode, does not show screensaver? Like that? Try to specify how its misbehaving, please 🙂
        If your PC does not hybernate, sleep or screensave, I would suspect some process “keeping the PC alive”. Example: your mose pad is not propriate and causes mouse cursor to move sometimes, not noticeably, but just once in few minutes. This can prevent from sleeping and hybernating..
        But as I said, we need more information.
        The basic thing to try is run this command (as administrator) in command line:
        powercfg –restoredefaultschemes
        This should reset your power schemes to default. If they do not work right now, what can you lose by trying this command, right 🙂
      • #2370594
        jgosney
        Yes PC does not EVER go to sleep or show screen saver.  this is even overnight.  I guess I can try and turn off my mouse & keyboard (wireless) in case some sort of vibration is wiggling it.   Thing is it used to work fine – with same mouse, etc.
        • #2370622
          doriel
          OK, try to unplug mouse and keyboard, thats good start.
          Then have a look, what your actual scheme is. If it is not in “full perfrormance” mode or so.
          Also try to reset your schemes with the CMD command above. You should be able to test all these in several minutes. Set screen saver for one minute for example, so you dontneed to wait too long.
      • #2370665
        jgosney
        No dice.   I turned screen saver off.  reset to default configs, then changed to “power saver” 1 min screen 2 minute sleep and no good.
        • #2370667
          doriel
          Is anything apart mouse and keyboard connected? USB external drive, camera, …
      • #2370671
        doriel
        Help Desk Geek post
        Here are several people complaining about the same. Seems like you are not alone in this one. Cant see any obvious way how to solve this apart of reinstalling W10 from scratch.
      • #2370799
        jgosney
        ok.   That did it. (not a reinstall – thank goodness!)  I had setup a flight simulator a few months ago.  It has USB rudders, yoke and throttles.  the rudder petals were still plugged in and that was it.  unplugged them and all is well.  thanks ..
    Reply To: Screen Saver and power settings quit
