Under my old Linksys EA2700, I had my Brother 5250DN printer connected through the router and available on my network.
When I switched the router to a TPLink Archer C7 V2, the router could not find the printer. The light on the printer ethernet plug blinks like something is going on. The router display for the port the cable is plugged into shows that something is plugged in.
I spoke to a few support people (in China?), one of who eventually had me add the printer MAC address to ARP list in the “IP & MAC Binding” section. After doing that, the printer was discovered and everything was working well. For a while anyway.
But over the next few weeks, I began to experience increasing problems with opening websites, seeing delays opening webpages as long as 30 seconds and/or webpage timeout messages. Bypassing the router and plugging the network connection directly into the PC eliminated these problems each time, proving that the problem was with the router.
I call TPLink support again and am told to reset the router (which will cause me to lose all my settings). I should also NOT reload the old settings from backup because something in there might be contributing to the problem. Sigh.
So I reset the router and entered each setting as it was before (I took screenshots to make sure I duplicated them exactly). Whew.
However, after recreating the settings, I was back to the printer not being shown/discovered/found.
Call TPLink support again. Verify settings. Reboot the router and computer and cable modem multiple times w/o success. Take another suggestion to make an addition to the “Address Reservation” section under the DHCP section. That did not work.
Decided to RMA the router.
When the replacement arrived, manually entered all the settings yet again. But the router will still not find/recognize the printer (yet the old Linksys EA2700 still does).
TPLink support does not know what to do. They claim they can’t test EVERY printer on the market, so [shrug] see ya…
I am running Win 8.1. The TPLink router has the latest firmware. I have changed the network cables all around.
Anyone have any ideas on what else I might try?
Edit:
Removed dump on TPLink router.
