  • word 2007 built in equation appearing problem
    Home Forums AskWoody support Microsoft Office by version Office 2010 and earlier for PC word 2007 built in equation appearing problem
    • This topic has 1 reply, 1 voice, and was last updated 4 weeks ago.
      • #2297890 Reply
        Guest
        Hi,
        I’m Rez. Recntly in word 2007 (win 7) whenever I go,
        Insert (tab) => Equation (down arrow)
        all the built-in equations in the menu are appearing in a strange way, some symbols are “up/down”  from others, some have strike through them. I already have repair and or uninstalled the entire office program but the problem does not resolved.
        Any help will be greatly appreciated, Thank you.
      • #2298183 Reply
        OscarCP
        The equation editor feature in older versions of “Office” has been deprecated by MS because of a security problem. Newer versions (from Office 2016 on, if I remember correctly), have instead the “Equation” option in the “Insert” menu, as well as “Symbol” that sometimes also comes in handy for writing mathematical formulas. I don’t know if this answers the question posed here, but it might be related to the answer, so I am mentioning it, just in case it helps.
    Reply To: word 2007 built in equation appearing problem
