I have Comcast Xfinity for my home internet service. I use their rental modem/router. The problem I am having is that it is difficult to get a reliable connection via wifi. Also, my powerline Ethernet adapters keep losing their connection and I have to re-pair them with the master unit.
If I run a long Ethernet cable to anything, it connects instantly and stays connected.
I believe I have figured out the problem: Xfinity combines the 2.4 Mhz and 5.0 Mhz hotspots into one joint hotspot, then assigns the channel and the speed based on what it thinks is best. Based on comments I have read online, this is the source of the wifi problem. But Xfinity doesn’t let you reconfigure the modem to separate the two hotspots, nor select the channel you want to use.
I believe I’ve found a solution: Get a wireless access point, and plug it directly into the modem. (There are four available Ethernet ports on the modem.) Then configure the wireless access point to have two separate hotspots: 2.4 and 5.0. I did this, and so far, so good. Things are working very well when I connect to one of those two hotspots.
It was either that or purchase a Comcast-compatible cable modem (could cost as much as US$200).
