• Combo Box Problem
    aflameI am trying to make a combo box that gives me a record according to what I select. The problem is that I don’t get the check button that says “Find a record on my form based on the value I selected…” when I use the combo wizard. What is the problem?!!! Is it because the boxes on my form are from a query? ARGGHH!!!! Please help me…somebody!
    • #522688
      Have you got the wizard button depressed?
      • #522689
        I’ve got the wizard pressed.
        • #522691
          So whats happening? You open the form in design view, depress the wizard button, click on the combo box button, click where you want the combo to appear, what happens then?
          • #522694
            It just comes up with the box that says “How do you want the combo box to get its values?”. It lists only two choices, not three.
            • #522695
              Ah! Right I see your problem.
              You are using an
            • #522838
              Okay, I’ll give it a try on Tuesday when I get back to work. Thanks, Rupert. I’ll let you know what happens.
              Jennifer
            • #523117
              Well, I tried it…and it didn’t work. You see I’m trying to incorporate 3 tables. I would like a screen where I can enter an invoice by first selecting the student that the invoice is for. That is where I can’t get the combo box to work–when I select a student. I have an invoice table that I want to get the invoice number from and then a fee table where I get the fee details for the invoice.
              Am I combining them incorrectly. I used a query that brought them all together. Or should I select from all 3 tables when I do the auto form?
            • #523128
              From what you have said I think you are constructing one of the most used applications in Access or any other db for that matter. What you have is a Customer, (The Student) an Invoice, and a product, (fee table). You could use any off the shelf accounts package for this, a free one like MYOB, or a sophisticated one like Sage or Pegasus.
              Or you could continue to programme it in Access. The beauty of using a product like Access is that you can apply business rules that aren
    Reply To: Combo Box Problem
