Background:
Database holds lot traceability records. Batch Nos are in form of “04108A1” where 04 is year, 108 is a sequential number recorded in a factory register, the 6th character is a machine type, and the 7th Digit is a Machine Id. (BTW, I hate ‘meaningful’ codes!).
I have a continuous form which allows for the review of batch nos, showing Raw Material Batch Nos, Dates, Shifts etc.
I need to be able to select from a combo box, the Left 5 characters, of batch nos, and list all records that start with those characters. I have tried using a calculated field in the underlying query for the form, which is calculated as BatchNo: Left([BulkBatch],5). This is the source of the Combo box. I then tried to set as criteria for the BulkBatch field, the value of the ComboBox. I suspect that I may have the equivalent of the Excel Circular Reference, because I get an error which when debugged, highlights the ‘Bookmark’ line of the code below.
Private Sub Combo15_AfterUpdate()
‘ Find the record that matches the control.
Dim rs As Object
Set rs = Me.Recordset.Clone
rs.FindFirst “[BatchNo] = ‘” & Me![Combo15] & “‘”
Me.Bookmark = rs.Bookmark
I am probably close to the solution, but just can’t see the wood for the trees.
TIA
