• Converting VBA Project to Word:Mac (VBA Office 2000)
    Home » Forums » AskWoody support » Productivity software by function » Visual Basic for Applications » Converting VBA Project to Word:Mac (VBA Office 2000)
    Greetings.
    I have a complex Word template written in both VBA and in legacy WordBasic.
    I recently tried to load it up in Word for the Max:X to see what ports and what doesn’t — and was suprised to find that the project was locked for viewing after being copied to the Mac.
    The project was NOT locked on the PC, though it did have a password. On the Mac, I was not asked for the password, justs forbidden access to the modules.
    Is there a trick to getting code from one platform to the other and still be visible?
    • #721781
      Did you try removing the password first? You could always try exporting then importing, though that can be a hassle if you’ ve got lots of mods.
      • #722183
        I haven’t tried it with the password completely removed from the PC template before copying to the Mac. I’ll try that.
        Exporting (using VBA Code Cleaner) would be simple. But I don’t think there’s a mac version (is there) that would make rebuilding automated.
        • #722193
          I don’t think so; you’d have to import manually.
        • #722194
      • #722184
    Reply To: Converting VBA Project to Word:Mac (VBA Office 2000)
