• CountIf problem (2003 SP3)
    Good morning
    I am currently using a number of CounIf formulas to add up the occurence of a letter in fields B5 – AQ5 and that is not a problem, what I would like to do though is to try and use the CountIf to add up H = 1 and h = 0.5 and still give me a total for instance if in the range B5 – AQ5 I had H occuring 5 times and h occuring 3 times the CountIf would = 6.5
    Any ideas please
    Cheers
    Steve
    • #1103433
      Steve,
      Is the ‘H’ or ‘h’ the sole contents of the cell, or are you counting any appearance of those letters within the cell contents? If they are the sole contents, then you can use:
      =SUMPRODUCT(--EXACT($B$5:$AQ$5,"H"))
      otherwise you would need a UDF I think – something like:
      Public Function CountIfExact(rngInput As Range, strCriteria As String) As Long
         Dim rngCell As Range, lngCounter As Long
         For Each rngCell In rngInput
            If rngCell.Text Like strCriteria Then lngCounter = lngCounter + 1
         Next rngCell
         CountIfExact = lngCounter
      End Function
      • #1103434
        Thanks Rory
        There are a number of letters involved that at the moment get counted into different cells, these are H (Holiday), S (Sickness) etc. and I have been asked to further break down leave days into 1/2 days or full days, I thought that the easiest way would be a Capital representing a Full Day and a Lower case representing a 1/2 day.
        Can you please exaplain in your first suggestion – =SUMPRODUCT(–EXACT($B$5:$AQ$5,”H”)) how that would determine H=1 or h=0.5, also what are the — before EXact for?
        I have never used UDF’s so if possible I will avoid them for now as I cannot understand 1 part of your example as it does not mention H or h or 1 or 0.5 in it anywhere confused
        Thanks for your attention
        Cheers
        Steve
        • #1103436
          Sorry, I should have been clearer – your complete formula would be:
          =SUMPRODUCT(--EXACT($B$5:$AQ$5,"H"))+SUMPRODUCT(--EXACT($B$5:$AQ$5,"h"))*0.5
          so that it counts ‘H’ and half of the ‘h’s
          the -- is there to force conversion of TRUE/FALSE values to 1/0 respectively.
          The UDF is generic, so you would have used:
          =CountIfExact($B$5:$AQ$5,"h")*0.5+CountIfExact($B$5:$AQ$5,"H")
          similar to the SUMPRODUCT formula. It sounds as though you don’t need that though if you only have one letter per day.
          • #1103437
            Thanks Rory
            I will go and play with that
            Cheers
            Steve
          • #1103517
            I’ve been trying to figure out a similar Countif. However, I don’t always have cells with unique values. For example, I want to count all A’s in a cell. It could be ABC, BA, AC, or A. I never have more than 3 letters in a cell and the A can only appear once. I was going to use a lot of cells to come up with a series of formulas, but if you have a nice, elegant UDF (or other solution) I’d appreciate the help!
            • #1103526
              You can use:
              =COUNTIF(B5:AQ5,"*A*")
              adjusting the ranges as necessary, if you don’t need it to be case sensitive?
            • #1103527
              You can use a formula like this:
              =COUNTIF(A1:A100,"*A*")
              The asterisks * are wildcards that stand for “any number of characters (including none)”
            • #1103531
              Thanks Hans and Steve. I was making it much too hard!
            • #1103552
              whisper The reply was from Rory, not Steve!
    • #1103435
      Actually, that was dense of me – for a find within other characters, just use FIND:
      =SUMPRODUCT(--ISNUMBER(FIND("H",B5:AQ5)))
      grin
    Reply To: CountIf problem (2003 SP3)
