• Create Hyperlink in Column using VBA Code
    Home » Forums » AskWoody support » Productivity software by function » MS Excel and spreadsheet help » Create Hyperlink in Column using VBA Code
    Hello Everyone!
    I am trying to create auto hyperlink from sheet1 to sheet2 using VBA code
    condition is as follow:-
    cell in column J may have value “WON” / “LOST” / ” Active”.
    i.e if sheet1, cell in column J=”won” then create hyperlink in corresponding cell in column M to sheet2.
    Any Help on this will be highly appreciated.
    Thank u in advance
    Viewing 4 reply threads
    • #2357561
      This should do the trick:
      Private Sub Worksheet_Change(ByVal Target As Range)
      '*** Limiting the Worksheet_Change event to a firing when a single cell is changed
         Dim isect As Range
         Set isect = Application.Intersect(Range("J:J"), Target)
         If isect Is Nothing Then
           MsgBox "Ranges do not intersect" '*** Message can be eliminated if desired!
         Else
           '***Prevent following code from refiring Change Event ***
           Application.EnableEvents = False
           If UCase(Target.Text) = "WON" Then
             ActiveSheet.Hyperlinks.Add Anchor:= _
                             Target, Address:="", SubAddress:="Sheet2!" & _
                             Target.Offset(0, 3).Address(, , xlA1), TextToDisplay:=Target.Text
           Else
            Target.Hyperlinks.Delete   '*** Clear the HyperLink
           End If  '*** If UCase(Target.Text)
           Application.EnableEvents = True '*** Reset Events ***
         End If   '***    If isect Is Nothing Then
      End Sub  'End WorkSheet_Change
      Note: this code needs to be placed in the Sheet1 Module!
      HTH :cool:
      • #2357763
        Hello RG,
        Thanks for the prompt response on my query..
        The code worked fine.. but what I want is to have hyperlink in column M when any corresponding data in column J have “won” text selected.
    • #2357796
      Target.Offset(0, 3) will move the column in Sheet2 by 3 places, e.g. from J to M, while keeping the row number the same. Is that what you see?
    • #2357815
      Thanks RG
      That worked well..
      One more question is can we use “Match” function in hyperlink address?
      how to Use below formula in vba to get autohyperlink
      HYPERLINK("#Sheet2!E"&MATCH([@[Reference Number]],Sheet2!E:E,0),"Link to "&[@[Reference Number]])
    • #2357960
      Not exactly sure what you are trying to do?
      Where do you want the hyperlink placed?
      What do you want the hyperlink to reference?
      Why did the original solution not meet your needs?
    • #2358090
      Sorry RG, I am not well versed with Macro coding, But trying my bit.
      What I want to do is : (1). If value in cell J2 is “WON” then, create hyperlink in column N2. (2). But the hyperlink should be vlookup and match the same value Column O in sheet XYZ and Text to be displayed in column N should (“to link to & the text in column M”).
      Right now, I have used this formula to achieve the results in Column N -(“HYPERLINK(“#’XYZ’!O”&MATCH(ABC!$M2,XYZ!O:O,0),”Link to “&ABC!$M2)”).
      But I want to do it using VBA Macro. And evrytime new data is added it should automatically do the job in new added rows as well.
      For Better understanding I am attaching sample file link for your reference.
      Thank you in advance
      NJ
      • #2359371
        Any Update or Help on this !…
    Reply To: Create Hyperlink in Column using VBA Code
