Using Office XP.
How can I insert a cross reference to a caption without including the label.
I want to insert a reference to “Figures 1, 2 and 4” but can’t seem to find a way to not put “Figure” with the numbers.
I tried to modify the field code and “supress all non-delimiter characters” without success.
Please help.
Tks.
cross-reference without caption label
Home » Forums » AskWoody support » Productivity software by function » MS Word and word processing help » cross-reference without caption label
- This topic has 4 replies, 3 voices, and was last updated 15 years, 3 months ago.
AuthorTopicWSJC@OR
AskWoody LoungerJanuary 30, 2010 at 6:19 pm #466278Viewing 1 reply threadAuthorReplies-
WSGary Frieder
AskWoody LoungerJanuary 30, 2010 at 11:05 pm #1207433It looks like there’s nothing available within the built-in options for cross-references to captions, that will allow you to do that.
There is a workaround, that would be a pain to implement (and would have one very big drawback), but that might work in a limited capacity:
For every Figure caption in the document (or at least, for those you need to be able to set cross-refs to): Select just the number part of the caption. Then go to Insert > Bookmark, and add a bookmark by typing in a name that tracks the caption number, for example “Fig1”.
Then when you add the cross-references, add the cross-refs to the bookmarks, rather than the captions – this would let you get a result like “Figures 1, 2 and 4”.
The big drawback is that if you ever made any edits that changed the order of the captions, you could update the caption numbers automatically by updating the fields, but the bookmarks would still be stuck referring to the previously-assigned number. [Editing my edit – after yet more testing, I think the originally-identified drawback stands. – GF]
Gary
macropod
AskWoody_MVPJanuary 31, 2010 at 4:34 am #1207441It looks like there’s nothing available within the built-in options for cross-references to captions, that will allow you to do that.
…Gary
Hi Gary,
Why make it so difficult?
Simply insert the cross-reference in the normal manner, then select the cross-reference and press Shift-F9 to expose the field code, which will look something like:
{ REF _Ref218925266 h } or { REF _Ref218925266 }
Simply change this to:
{ REF _Ref218925266 # 0 h } or { REF _Ref218925266 # 0 }
by adding the ‘# 0′ – before the h (if it appears). When you’re done, press F9 again to update the field.The h switch in the above example indicates a cross-reference inserted as a hyperlink; if you chose not to hyperlink the cross-reference, the field will not have this switch.
See: ’The brilliant way’
Cheers,
Paul Edstein
[Fmr MS MVP - Word] -
WSGary Frieder
WSJC@OR
Viewing 1 reply thread -
5 hours, 50 minutes ago -
n0ads
38 minutes ago -
You can’t handle me
2 hours, 27 minutes ago -
1 hour, 29 minutes ago -
17 hours, 12 minutes ago -
4 hours, 45 minutes ago -
17 hours, 36 minutes ago -
17 hours, 41 minutes ago -
Lumma malware takedown
EyesOnWindows
5 hours, 57 minutes ago -
Meet Gemini in Chrome
Trump signs Take It Down Act
1 hour, 34 minutes ago -
16 hours, 48 minutes ago -
not so anon
1 day, 17 hours ago -
2 hours, 18 minutes ago -
hibernate activation
e_belmont
2 days, 2 hours ago -
2 days, 9 hours ago -
Out of band for Windows 10
2 days, 14 hours ago -
Giving UniGetUi a test run.
2 days, 21 hours ago -
3 days, 5 hours ago -
Auto Time Zone Adjustment
wadeer
3 days, 9 hours ago -
Eddieloh
3 days, 7 hours ago -
Mary Branscombe
7 hours, 5 minutes ago
