I have an Excel sheet I post every week and it has a pivot table report in it. I have a Marco that cycles all of the data within the pivot table and prints a page for each selection. I have posted the code for it. I was wondering if there was a way to skip a page if there was no data for that selection to print?
Do not print using VBA (Excel 2002)
Home » Forums » AskWoody support » Productivity software by function » MS Excel and spreadsheet help » Do not print using VBA (Excel 2002)
- This topic has 4 replies, 2 voices, and was last updated 19 years, 5 months ago.
AuthorTopicWSrk_winston
AskWoody LoungerDecember 20, 2005 at 3:17 pm #427603Viewing 0 reply threadsAuthorReplies-
WSsdckapr
WSrk_winston
AskWoody LoungerDecember 20, 2005 at 7:04 pm #991229I was thinking while at lunch that I did not make my self very clear.
A macro was written a few years ago for me that would select and print each block/line then each shift in the pivot table. The macro would cycle through all of the data. Even though something was selected, there might not be any data in the detail section of the pivot table. I would like to skip the printing of the ones with out the data.
My VBA skill for Excel is lacking, as I do not know the proper way to check for the data in the detail section of the pivot table. I was hoping for a push in the correct direction or an example of how to do this.
I attached an example of the pivot table with made up data as requested too.
WSsdckapr
AskWoody LoungerDecember 20, 2005 at 9:59 pm #991272Does this do what you want?
SteveSub PrintBlock(BlockName As String) With ActiveSheet.PivotTables("BlockShift") .PivotFields("Block/Line").CurrentPage = BlockName If (BlockName = "QH01" Or BlockName = "Materials") Then .PivotFields("Shift").CurrentPage = "(All)" Dim a If .GetPivotData("Sum of Qty -1") 0 Then ActiveWindow.SelectedSheets.PrintOut Copies:=1 End If Else .PivotFields("Shift").CurrentPage = "1" If .GetPivotData("Sum of Qty -1") 0 Then ActiveWindow.SelectedSheets.PrintOut Copies:=1 End If .PivotFields("Shift").CurrentPage = "2" If .GetPivotData("Sum of Qty -1") 0 Then ActiveWindow.SelectedSheets.PrintOut Copies:=1 End If If (BlockName = "BI" Or BlockName = "BD04" Or BlockName = "TRPR" _ Or BlockName = "PRSS" Or BlockName = "200 TON" Or _ BlockName = "200 TONU" Or BlockName = "400 TON") Then .PivotFields("Shift").CurrentPage = "3" If .GetPivotData("Sum of Qty -1") 0 Then ActiveWindow.SelectedSheets.PrintOut Copies:=1 End If End If End If End With End Sub
WSrk_winston
Viewing 0 reply threads -
Phishers extract Millions from HMRC accounts..
6 hours, 2 minutes ago -
Windows 10 22H2 Update today (5 June) says up-to-date but last was 2025-04
Alan_uk
7 hours, 54 minutes ago -
Thoughts on Malwarebytes Scam Guard for Mobile?
opti1
11 hours, 3 minutes ago -
Mystical Desktop
11 hours, 16 minutes ago -
Meta and Yandex secretly tracked billions of Android users
6 hours, 3 minutes ago -
MS-DEFCON 2: Do you need that update?
1 hour, 27 minutes ago -
CD/DVD drive is no longer recognized
WSCape Sand
Windows 11 24H2 Default Apps stuck on Edge and Adobe Photoshop
MikeBravo
North Face and Cartier customer data stolen in cyber attacks
What is wrong with simple approach?
WSSpoke36
19 hours, 56 minutes ago -
Microsoft-Backed Builder.ai Set for Bankruptcy After Cash Seized
Location, location, location
5 hours, 15 minutes ago -
Cannot get a task to run a restore point
Frustrating search behavior with Outlook
MrJimPhelps
June 2025 Office non-Security Updates
2 days, 3 hours ago -
Secure Boot Update Fails after KB5058405 Installed
SteveIT
5 hours, 35 minutes ago -
Firefox Red Panda Fun Stuff
Lars220
2 days, 2 hours ago -
Davidhs
2 days, 13 hours ago -
2 days, 22 hours ago -
lmacri
2 days, 11 hours ago -
Firefox 139
Charlie
2 days, 4 hours ago -
Who knows what?
16 hours, 21 minutes ago -
Misbehaving devices
WSmeyerbos
4 days, 4 hours ago -
4 days, 3 hours ago
