• Dos unlock problem
    When I have no other applications running, and using DOS in administrator mode, I have tried to diskcopy my a: disk.
    However, I get an error messsage saying:
    Cannot lock current drive.
    Under DOS how does one lock or unlock a disk drive ??
    Thanks for any help… Theodore
    • #1232636
      If you are still using a 3.5 inch floppy drive then the disks can be locked or unlocked by manually sliding a small plastic square slider in one of the corners of the floppy. When you can see through the hole the floppy is locked.
      I don’t know how to lock a floppy disk by typing commands in DOS so I can’t help you if you have already put the disk inside the computer.
    • #1232674
      Try this.
      Code:
      c:
      diskcopy a: b:
      BTW, why are you copying floppy disks?
    Reply To: Dos unlock problem
