LANGALIST By Fred Langa The final LangaList for 2020 takes a look at a subscriber’s PC with a strikingly unusual configuration. It’s a high-capacity m
[See the full post at: Drive-dense system suffers from sub-par performance]
Home » Forums » Newsletter and Homepage topics » Drive-dense system suffers from sub-par performance
- This topic has 8 replies, 8 voices, and was last updated 4 years, 5 months ago.
AuthorTopicTracey Capen
AskWoody MVPDecember 27, 2020 at 9:05 pm #2323125Viewing 5 reply threadsAuthorReplies-
8string
AskWoody PlusDecember 28, 2020 at 4:51 am #2323214A good thing to know given that many of us who do video editing have many many hard drives lying around. I probably have close to 15 on the shelf that I use regularly, but I don’t plug them in all at once.
What about backing up those 15 drives ?
Wouldn’t a NAS with RAID be a better solution ? -
AskWoody MVP -
GoneToPlaid
AskWoody LoungerDecember 28, 2020 at 9:55 pm #2323514I have 10 active hard drive partitions (on 3 internal hard drives). I also have 32GB of RAM. Desktop computer is Windows 7. My RAM usage also is between 16 to 17 percent (5 to 6 GB), even if I only have drive C: actually connected to the computer. It simply seems that the more RAM you have installed, the more that Windows will make use of it.
Some other thoughts…
The Windows disk defragmenter is disabled since I use a third party program for this task. The third party disk defragmenter app does not launch on startup. It is strictly a run only when manually launched thing.
Looking at Fred Langa’s post and what he quoted from the person who “thinks” that they are having issues…
The pagefile should be fixed in size — period. More importantly, the pagefile should not be heavily fragmented. This can occur if the pagefile is not created while in Safe mode and if the OS hard drive also is heavily fragmented. I have seen this issue dramatically occur with an OS hard drive (now replaced) which was having severe hardware related I/O issues such that the hard drive I/O controller was throwing hundreds of interrupts per second.
Running SFC /scannow can populate this folder with thousands of files, which must be properly cleared only by using specific commands at the command prompt, or by using a specific feature of Disk Cleanup. This specific folder is:
Windows\winsxs\Temp\PendingRenames
Never delete anything in the above folder! If you do, you will brick your Windows installation! The commands to properly clean up the PendingRenames folder varies with each Windows OS version.
Run chkdisk, on all drives, with no repair options. Even if chkdisk is run without any repair options, chkdisk actually does perform some cleanup issues for NTFS itself, even though no errors are reported. Occasionally this is enough to resolve some mysterious issues.
These are my personal observations regarding issues which I have observed in the past.
WSsmylrea
AskWoody LoungerDecember 29, 2020 at 1:40 pm #2323796My new laptop has 16GB and 1TB SSD. My map drives are 3 to my NAS. The NAS has 6 – 10TB in a Raid 6. I also have 3 map drives to my desktop. 1 is a 6TB mirror drive and the other is a 6TB (4- 2TB raid 5). So I have 12 drives connected with 52 TB’s. Reboot is about 35 seconds. If you have individual drives go to a Raid system. If you want an easy to use raid system look at Synology. I have an 8 drive system DS 1618+. I am retired and have a lot of photos and store a lot of my information searches. I also like to backup my and my wife’s computers.
This reply was modified 4 years, 5 months ago by
PKCano.
WSsmylrea. Reason: wrong numbers
GoneToPlaid
GuestDecember 29, 2020 at 7:21 pm #2323869The first Synology I had was about 10 years ago. It was an inexpensive 4 drive unit. It lasted about 5 years and failed. I was a little upset about that and built my own NAS system. It was a FreeNAS 8 drive unit with 4TB drives in a Raid 6 with 1 spare. It was a nice system if you like to play with computers and networks. It also does not like it when you are at 80% full. That lasted for 3 years and i decided that I would get enough drives so I would not run out of space. My eldest son and his wife had a much newer Synology unit. They use it for their movie, music and game storage. He is a senior programer for a local world wide company. He likes the Synology because it is easy to use has a lot of programs to use the storage and is constantly being upgraded. So I went with a DS 1618+ 8 drive unit. The Plus because it is the commercial unit and was not that more expensive. I also watched Amazon for awhile for when it was on sale or a very good used like new one came a long and got it for $200 less then new. It may have had some scratches on it but had the full warranty. I have 7 10 TB disks in it in a S2 type raid. I started with 5 disk in a S1 because of costs. I love it and it is very easy to keep updated. I use their programs to automatically back up our 4 computers. I am using 43% of the drive (11.3TB).
If you are looking to go with a NAS, you need to see what you want to do with it. You can use it as backup for your computer. Use it as another drive by mapping it to your computer. You can also use it with the many other programs they have like a security video storage. Then you need to think how much storage you will need and multiply by 4. You want to go with Raid 5 or S1 because at least one of your disks will fail. That will give you time to get a new one to replace the bad disk. I like to have space to go to Raid 6 or S2 with a spare disk that will automatically replace the bad one and notify you. I also have space to add another disk if I start to get full again.
I hope this has helped. Go to Synology’s site and research all the many things you can do with it.
Paul T
Viewing 5 reply threads -
Office gets current release
19 minutes ago -
10 hours, 15 minutes ago -
6 hours, 59 minutes ago -
Stop the OneDrive defaults
11 hours, 3 minutes ago -
20 hours, 59 minutes ago -
X Suspends Encrypted DMs
23 hours, 11 minutes ago -
23 hours, 29 minutes ago -
M W Leijendekker
12 hours, 53 minutes ago -
Enabling Secureboot
ITguy
19 hours, 53 minutes ago -
No more rounded corners??
Android 15 and IPV6
18 hours, 11 minutes ago -
1 day, 23 hours ago -
2 days, 7 hours ago -
May preview updates
1 day, 9 hours ago -
crown
jkitc
22 hours, 26 minutes ago -
Botswana12
2 days, 22 hours ago -
16 minutes ago -
3 days, 10 hours ago -
Dave Easley
gtd12345
4 days ago -
Another test post
gtd12345
4 days ago -
wadeer
1 hour, 35 minutes ago
