My wife’s computer wouldn’t boot last week and after working with it a while I decided it likely had a bad sector on the hard drive in the Windows folder. May or not be the case but after fighting the thing for a couple hours I decided to just install a new drive and reinstall her programs. Her data is all on a separate data drive so I figured not that big a deal.
The original drives were both IDE. I bought a new SATA drive for the fresh install.
After the installation the new drive was assigned “F” instead of “C”. Both IDE drives were disconnected during the install, but the CD drive……….which is also SATA……..was of course connected.
Is this drive assignment of “F” because I have the CD drive in a MB connector that supersedes the HDD connector. IE………will swapping the cables solve this problem?
I tried to use DISK MANAGEMENT to change the letters but it won’t let me do so on the primary drive with the MBR.
If the problem IS because of a SATA connector primary/secondary issue, will just swapping the cables assign “C” to the new HDD? Or will I have to reformat and reinstall Windows again?
Thanks for the help. Sometimes it seems I know just enough about all this to make a lot of trouble for myself !!
BH
