• Excel 2010: VBA problem toggling subscripts
    Home » Forums » AskWoody support » Productivity software by function » Visual Basic for Applications » Excel 2010: VBA problem toggling subscripts
    I have strange behaviour with a Macro to toggle a Subscript in an Excel 2010 Cell.
    My Macro will toggle the values show in Row 1 to have the final character of the string in the selected cell converted to a Subscript as shown in Row 3.
    36763-20140411-Sheet-capture
    However, trying to reverse the process works sometimes, but rarely.
    Here is my VBA code for the Macro:
    Code:
    Sub Subscript()
    Dim sFontName As String
    Dim sFontStyle As String
    Dim sFontSize As Long
    Dim sStringLength As Long
    Dim sSubscript As Boolean
    Dim Msg, Button, Title, Response As String
    Button = vbExclamation
    ActiveCell.Select
    sStringLength = Len(ActiveCell)
    sFontName = ActiveCell.Characters(Start:=sStringLength, Length:=1).Font.Name
    sFontStyle = ActiveCell.Characters(Start:=sStringLength, Length:=1).Font.FontStyle
    sFontSize = ActiveCell.Characters(Start:=sStringLength, Length:=1).Font.Size
    sSubscript = ActiveCell.Characters(Start:=sStringLength, Length:=1).Font.Subscript
            Title = “Test for Subscript 0 …”
            Msg = “Font Name:      ” & sFontName & vbCrLf & _
                    “Font Style:     ” & sFontStyle & vbCrLf & _
                    “Font Size:      ” & sFontSize & vbCrLf & _
                    “String Length:  ” & sStringLength & vbCrLf & _
                    “00 Subscript:      ” & sSubscript
            Response = MsgBox(Msg, Button, Title)
    If sSubscript Then
            Title = “Test for Subscript Initially True 1.0…”
            Msg = “Before Subscript Toggle:      ” & sSubscript
        ActiveCell.Characters(Start:=sStringLength, Length:=1).Font.Subscript = False
            Title = “Test for Subscript Initially True 1.1…”
            Msg = “After Subscript Toggle:      ” & sSubscript
    Else
            Title = “Test for Subscript Initially False 2.0 …”
        ActiveCell.Characters(Start:=sStringLength, Length:=1).Font.Subscript = True
            Title = “Test for Subscript Initially False 2.1 …”
    The code has numerous messages in it to display the status of the action, hence it looks long and complicated – it’s not really.
    Any bright ideas on why this code is not working correctly?
    Thanks in anticipation for all assistance.
    Trevor
    • #1448414
      Trevor,
      This seems to work consistently.
      Code:
      Option Explicit
      Sub Subscript()
         If sSubscript Then
           ActiveCell.Value = ActiveCell.Value
         Else
      End Sub   'SubScript()
      • #1448528
        Hi RetiredGeek,
        Thanks, yes that does exactly what I desire – it toggles the Subscript on and off depending on how the last character in the string is set.
        Cheers
        Trevor
    • #1448416
      Since your thread title mentions toggling:
      Code:
      Sub ToggleSubscript()
      With ActiveCell
        On Error Resume Next
        .Characters(.Characters.Count).Font.Subscript = Not _
      End With
      Cheers,
      Paul Edstein
      [Fmr MS MVP - Word]
    Reply To: Excel 2010: VBA problem toggling subscripts
