• Excel 2016 Problem with VBA Function and Text Import
    Home » Forums » AskWoody support » Productivity software by function » MS Excel and spreadsheet help » Excel 2016 Problem with VBA Function and Text Import
    Good day, everyone. I’m a pharmacist with the Department of Veterans Affairs, and I frequently have to import text files created on our local network. One of the fields is the National Drug Code (NDC) number. Many of those numbers start with leading zeroes which have to be there to make sense. I have to import the field as Text, else all the zeroes disappear. Then I have to change the format to General, else the formulas don’t work. One attachment is a picture of what the data should look like. The formula works if the NDC # field is 12 characters long. Sometimes it isn’t. A few years ago I got some help to create a VBA function to format the NDC code. Here it is.
    Option Explicit
    Public Function NDC(ByVal X As Variant)
    Dim m
    If Right(X, 1) = ” ” Then
    m = Left(X, 5) & “-” & Mid(X, 6, 4) & “-” & Mid(X, 10, 2)
    ElseIf Len(X) = 12 Then
    m = Left(X, 6) & “-” & Mid(X, 7, 4) & “-” & Right(X, 2)
    ElseIf Len(X) = 11 Then
    m = Left(X, 5) & “-” & Mid(X, 6, 4) & “-” & Right(X, 2)
    ElseIf Len(X) = 10 Then
    m = Left(X, 4) & “-” & Mid(X, 5, 4) & “-” & Right(X, 2)
    Else
    m = “error”
    NDC = m
    End Function
    When I try to insert the function now, I get an error message. A capture of that is attached also. I can’t figure out why the VBA function doesn’t work. Thanks for any help!
    Reply To: Excel 2016 Problem with VBA Function and Text Import
