• Excel Print Problem
    I am trying to spruce up an invoice I created in Excel. (2002)
    I have put a colored text box over information at the top of the sheet. The text box transparency is set to 70%. On the computer screen I can see the information behind the box, but when it is printed, the text box covers the information and none of the information behind the box is printed.
    I have tried, “no fill”, “100% transparent”, I have sent the box to the “back”, I have also tried all of this with an auto shape box.
    What am I missing here?
    • #1322472
      Marv,
      Select the Textbox.
      Right-Click the Border.
      Select Move to Back.
      Should work.
      The other option is to color the cell backgrounds. :cheers:
      • #1322900
        Thanks for the reply, but,
        Already tried that, problem still exists
      • #1322901
        I know I can colour the cell backgrounds, but then the colour cannot be shaded dark to light
    • #1322917
      Harv,
      This may be a problem with the printer driver or just a feature it doesn’t support. I tried a test, unfortunately using Excel 2010, and it worked just fine on an HP 2400 series Deskjet printer {a fairly OLD printer as printers go}. However, when I attempted to print to a PDF file using PrimoPDF {a different driver at work here} none of the cells showed through I just got a blue to white shaded block.
      Test 2: I booted my laptop with Excel 2003 and tried again. This time I got the same results as you did, on the 2400 and my Brother Laser printer, so I guess what you need is a newer version of Excel to accomplish what you are trying to do. :cheers:
    • #1324578
      Thanks RetiredGeek:
      I believe you are correct, as I have tried that myself. I really do not want to buy more software, so will need to live with it.
      Also I just may try to print on another printer. I’ll let you know.
      Harv
    Reply To: Excel Print Problem
