Susan Bradley’s article on Nov. 25 regarding end of the road for IE versions spurred to me action. I have Windows 7 PRO SP1 (64 bit). I had IE 10 installed, which worked great. So I downloaded ‘IE11-Windows6.1-x64-en-us.exe’ and installed IE 11.
I found a problem with a website I created, so I went to F12 Developer. It would not open, and gave me an error. I searched for that error code, which led me to ‘IE11-Windows6.1-KB3008923-x64.msu’, which I installed. That fixed the F12 problem, but not my website. Checking KB3008923 in Windows Secrets, eventually led me to the latest cumulative update, ‘IE11-Windows6.1-KB3100773-x64.msu’, which I also installed. Still no solution to my website problem.
But I have three questions:
1. Since I have installed the latest cumulative update, are their other updates that I need to install, or does the cumulative get all preceding updates–i.e., could I have skipped ‘IE11-Windows6.1-KB3008923-x64.msu’? And if there are some updates I am missing could you list them? And do they have to be installed in any specific order?
2. The F12 Developer seems to have been significantly changed since IE 10. In IE 10 there was a Browser Mode and a Document mode. Each could be changed independent of the other. In IE 11 there is an Emulation tab, which contains a Document Mode, but no Browser Mode. There is a User agent string. Is that the same a Browser Mode?
3. The default for Document mode and User Agent string are Edge. There is no IE 11 listed. I thought Edge was a newer browser than IE 11. Can someone shed light on this?
Thanks for your understanding.
Harry
