• filtering a query with IIf statement problem
    Home » Forums » AskWoody support » Productivity software by function » MS Access and database help » filtering a query with IIf statement problem
    I get code blocked when inserting the sql I want to ask about, so.
    I want to filter PO records only if a value is greater than 7. 7 is a rep number. I want reps greater than 7 to only see their own PO’s but anyone less (managers) to be able to see all PO’s.
    I’m trying to use an IIF statement with Like “*” as the false value but it returns nothing.
    Viewing 4 reply threads
    • #2276192
      Here is a pic showing my code
      Annotation-2020-06-29-152634
    • #2276199
      I would have expected something like “select * where userinfo > 7” rather than an IFF.
    • #2276242
      Here’s what you want …  IIF(GetUserInfo()<=7,Rep,GetUserInfo())
      Jim
    • #2276249
      Our Access teacher told us, that IIF is just normal IF, but it has to named otherwise not to colide with other IF function.
      iif
      Also, beware of the “wildcard symbol”. Since you work in access, * should be right, but maybe there should be just single quotation (alt+39) instead of double.
      https://www.w3schools.com/sql/sql_like.asp
      @jimatVirginiaSoftware
      solution seems viable.
      PRUSA i3 MK3S+
    • #2276379
      Jim was right: IIf(GetUserInfo()<=7,([Rep]),GetUserInfo()) did the trick.
    Reply To: filtering a query with IIf statement problem
