Can anyone help me with a problem with my Gateway 3300 Laptop battery pack
The battery has “frozen up”
By that I mean that I can’t run the 3300 on the battery, the beast jest won’t Boot-up on battery power,only with A/C power
I checked the Battery status by pushing the little white spot underneath the 3300 and all 4 green LED’s light up indicating that the battery is fully charged
I also checked the battery conditon via Windows Power Management in the Control Panel area and that showed that the battery was 100% charged, but also showed that it was “charging” !!
With the AC adaptor connected the Battery indicator green and orange LED’s both flashn on and off at 5 second intervals (whatever that means !!) There is no mention of thei phenomena in Gateway’s 3300 Manual
I also carried out the Battery Training routine via the BIOS commands and when I ran that it immediately told me that the battery was already “Trained” and charged to 2700mAH’s !!
I’ve been told that there is a software program which will run a discharge cycle on the battery so that it gets its “mind” restored
I was then told by a Battery Restorer company that there was probably a faulty cell and I should repack the battery
This made a bit of sense to me as the battery pack was ca. 2 years old so I had the battery pack re-celled but on installing it, it exhibits exactly the same problems *&^%$&
Can anyone suggest what may be wrong and how to rectify the problem
Awaiting assistance
Cheers n Tears
Max
mrieper@optushome.com.au
