• Help Function Problem
    When I press F1 while in Excel 2007 (or, for that matter, any other Office app), all I get is a pop-up stating “There are no help topics available that match your request”. However, I haven’t made any request (that I know of). Any idea what is going on with the Help function and how to fix it?
    I just noticed that the title bar in the pop-up says “Microsoft Office Help Viewer. Must that be installed along with Office 2007?
    • #1247584
      Hi Chuck,
      When you installed Office, did you install the Help files? You can check the setup via a ‘change’ installation, using ‘Add/Remove Programs’ or ‘Program and Features’ in the Windows Control Panel.
      Cheers,
      Paul Edstein
      [Fmr MS MVP - Word]
    • #1248218
      I reinstalled Office and that cured the problem.
    Reply To: Help Function Problem
