Hi Guy’s,
Getting more than a little desperate here. Got myself a speedy wee system & installed Win XP Pro SP3 with all the current updates on it. 1.75 Gb Ram with a 40gb hard drive & a 250 back up Slave drive.
I’ve checked using Aida & need links for drivers for the following, as I cannot seem to locate them, at least, not the correct ones.
Aida identifies the missing drivers as:
Intel 82801 EB/ER AC’97 Audio Controller, &
Intel Springdale-G i865G Motherboard Chipset.
The side cover with info. about model number, etc, is missing so I can’t help there.
I’ve been both to Hp & Intel, but no luck…
Any help would be great!
Thanks,
Mike
