• Help with SQL String
    • This topic has 3 replies, 3 voices, and was last updated 15 years ago.
    Hello Folks,
    I’ve never done much with SQL and I’m trying to use a SQL string to append a record to a file from a button on a form. I have a user who is computer challenged so I can’t just use the add record button. Here’s the code I’ve cobbled together from doing an append query looking at the SQL and looking at some of the SQL posts on the board. I keep getting the attached message.
    Code:
    Dim iNewLotNo As Integer
    Dim zSqlStr   As String
    On Error GoTo Err_cmdNewRecord_Click
        iNewLotNo = InputBox("Enter the New Storage Lot Number", "Add Storage Lot", 0)
        If iNewLotNo = 0 Then
          GoTo Exit_cmdNewRecord_Click
        Else
          'SQL Code here
          zSqlStr = "INSERT INTO StorageLots ( [StorageLotNo], [OwnerID] )" & _
                    "WHERE ([StorageLotNo]=" & iNewLotNo & _
                    ", [StorageLots.OwnerID]=600);"
          DoCmd.RunSQL zSqlStr
    So, I figure I’m missing a qoute or comma somewhere?
    Thanks,
    • #1223261
      The trick in debugging this sort of stuff is to put a breakpoint in VBA on the DoCmd.RunSQL line and then do a print of the SQL String and that will usually tell you where the error is when you look at the string. If it isn’t obvious just looking at it, paste it into a new query in the SQL view and then switch to Design View and that will show you where the error is.
    • #1223262
      I am not quite sure what the WHERE bit of your SQL is doing.
      I am assuming you want to Insert a Couple of VALUES to the Table StorageLots as an Append Query
      But you have NO values to Append in your SQL
      Syntax would be
      Code:
      zSqlStr = "INSERT INTO StorageLots ( [StorageLotNo], [OwnerID] )  SELECT  " &  iNewLotNo & "  AS [NewNo],  600 As [OwnerID] ; "
      Note [NewNo] and [OwnerID] are just Temporary names for the SQL, they do not represent REAL fields
    • #1223266
      AKW,
      Thanks much works like a charm.
    Reply To: Help with SQL String
