• Help with vba code
    Hi,
    I am struggling to compile some code that is technically beyond my capabilities, so would really appreciate some help.
    I have added comments to the code below that hopefully explain what I am attempting to do.
    Code:
    Sub Test()
    Dim amt As Worksheet, ath As Worksheet, aat As Worksheet
    Dim r As Long, s As Long
    Dim x As Range, y As Range, z As Range
    Dim j As String
    	Set amt = Worksheets("Admin MGR History")
    	Set ath = Worksheets("Admin TFR History")
    	Set aat = Worksheets("Admin Action TFR'S")
    	r = aat.Cells(Rows.Count, 3).End(xlUp).Row
    	'irrelevant code removed
    	j = aat.Range("E5")
    	'Now I need to capture the row number that j is on in amt, column A, rows 2 : endxlup
    	'This becomes the destination row
    	Set x = aat.Range("K35:K" & r)
    	For Each y In x
    	'Copy y.offset(0,13) and paste as special values to the first blank cell in the range of >
    		'either BZ, CC, CF, CI or CL on the destination row
    	'Then copy y.offset(0,17) and paste as special values to the first blank cell in the range of >
    		'either CA, CD, CG, CJ or CM on the destination row
    	'Find y on the destination row (which will be within the range of columns E:P) and >
    		'replace it with y.offset(0, -8)
    	Next
    Viewing 6 reply threads
    • #1179874
      It is appreciated that:
        [*]the material on which you’re working may be confidential
        [*]you don’t want to burden us with excessive detail
      Nonetheless, it could be helpful if you could post a sample workbook – as (for me at least) a wider perspective on your problem could be helpful.
      HTH
      • #1179879
        HTH
        Ok, Thanks. Not majorly confidential, but there is a lot of excess in the file. I am trying to sort out a stripped down copyof the 16mb file, after removing the vast majority (about 80%), the file size is still 13mb.
        I’ll keep trying…..
    • #1179885
      Here goes….
      I have had to remove the vast majority of the formula’s due to the fact that they were looking at one sheet that is 11mb and I could not reduce it. That sheet contains a web query.
      Hopefully this will be enough to give the general idea.
    • #1179896
      ‘Now I need to capture the row number that j is on in amt, column A, rows 2 : endxlup
      ‘This becomes the destination row
      Hi Nathan
      Can you further explain “amt, column A, rows 2 : endxlup”
    • #1179901
      Hi Don,
      This has moved on somewhat (Very slowly) and I am (slightly) past that point.
      Hopefully the attached explains where I am now stuck.
      Thanks for any help.
      • #1179902
        Range(p, q) is the rectangular range with p and q as opposite corners. If you want to copy two non-adjacent cells, you must copy each of them individually.
    • #1179906
      So a non contiguous range cannot be copied? I was not aware of that.
      • #1179907
        You *can* copy a non-contiguous range, but not with the syntax you tried.
        If you have two ranges p and q that represent non-adjacent cells, you’d have to use
        Union(p, q).Copy Destination:=r
        But even if p and q are non-adjacent, they will be copied into adjacent cells. There is no way to copy for example A1 and E1 into A5 and E5 in one go.
    • #1179910
      Thanks Hans, I’ve only just seen your post, I was beavering away and am now nigh on complete.
      I am struggling with the very last little bit and would appreciate any help that loungers can offer.
      Updated:
    • #1179917
      Code:
      Set w = amt.Range("E" & p & ":P" & p).Find(What:=y.Value, LookIn:=xlValues, LookAt:=xlWhole)
      	w.Value = y.Offset(0, -8)
      Got there eventually.
    Reply To: Help with vba code
