I have data in Col K & L. Where the values in Col K < than the value in Col L, then the cell/s in Col K that is less than the value in Col L in the same row as Col K must be highlighted in Blue
I have tried to do this using conditional formatting but cannot get it to work. I have set up a separate sheet (desired result) to show you what it should look like if conditional formatting was applied
Your assistance in resolving this will be most appreciated
