• How do I define a bulleted style using VBA? (VBA/Word/2002 SP-1)
    Home » Forums » AskWoody support » Productivity software by function » Visual Basic for Applications » How do I define a bulleted style using VBA? (VBA/Word/2002 SP-1)
    I want to be able to modify a bulleted style using VBA. You’d think I could just record a macro that would do just that, but when I record said macro, even though the results of the actions I recorded look just fine in the document, when I run the macro I get hollow squares instead of bullets. In the recorded macro there’s a section that starts,”With ListGalleries(wdBulletGallery).ListTemplates(2).ListLevels(1)” that contains the line “.NumberFormat = ChrW(61623)”. I’ve changed this to “.NumberFormat = ChrW(2022)” [2022 is Unicode for bullet] to no avail. I still get hollow squares! Can anybody help?
    • #633672
      Are you sure the list level applied is 1 and not some lower level? This is probably in the last line of the recorded macro.
      I would also check the typeface applied to the character. The square box is possibly coming out of a font issue where that character does not exist in the typeface chosen for the bullet. 2022 may only be Unicode for a bullet in one particular typeface and not in another.
    • #633675
      Hi margot,
      Following up on Andrew’s post, try character 0149. That’s the key code for a bullet in almost every font.
      Cheers
      Cheers,
      Paul Edstein
      [Fmr MS MVP - Word]
    Reply To: How do I define a bulleted style using VBA? (VBA/Word/2002 SP-1)
