How to make my sql work with zero values
I have a valid sql clause as follows
strSQLSupplier = “UPDATE Products SET Stock = Stock + ” & Me.Quantity & ” WHERE ProductID=” & Me.Productid
The above SQL clause works only if the field
Home » Forums » AskWoody support » Productivity software by function » MS Access and database help » how to make my sql work with zero values
It sounds like the value of the stock field is not zero, but is null. Null is not zero and null plus any number is null.
You will probably need to do two things. First change the table definition so that the default for the stock field is zero. Second, you will need to update all of the records in your table with null stock to zero.
Notifications
