I’m running Win 7 Pro SP1 on my computer. I run my internet cable (from Comcast) directly into my modem (which Comcast provides). From the modem, I connect to my router (an older Belkin N150 router) via an ethernet cable. I connect the router to my desktop computer via an ethernet cable from one of the 4 available ethernet ports on the router. So my desktop computer is basically hardwired to the modem via the router.
I have an excellent internet connection (nominally, according to Comcast, the latest 100 Mbps speed that they offer). When I actually test my speed (using Speedtest.net), I’m consistently showing downlink speeds of around 68 Mbps and upload speeds of around 12.2 Mbps (not bad by any measure).
As an experiment, I removed my router from the loop (i.e., I connected my modem directly to my computer via an ethernet cable), and my speeds increased significantly (at least my downlinklink speed did) to about 104 Mbps downlink and 12.3 uplink.
Let me be clear: I’m not writing to complain about any of these speeds. But I’m curious. Why would putting the router in the loop (remember, I’m only talking about the hardwire connection, not wi-fi) cause such a large speed drop? Is this typical, or would it possibly improve with a newer router?
Thanks for any info you can provide.
