• Kernel-Power crash problem
    Home » Forums » AskWoody support » Windows » Windows 7 » Questions: Windows 7 » Kernel-Power crash problem
    Hi Guys,
    My Laptop computer keeps crashing. I have tracked the problem to Kernel-Power but don’t know how to fix it.
    I use Windows 7 Home on an Acer Aspire 5740G.
    I’ve37882-Screenshot-11_09_2014-4_30_37-PM37883-Screenshot-11_09_2014-4_32_00-PM attached a couple of screenshots of the Event viewer, there are two because all wouldn’t fit on one.
    Thank you for your help.
    Cheers,
    Bob Slatyer.
    Viewing 8 reply threads
    • #1467236
      POWER
      Does this occure while plugged in, if not, is there sufficient power in the battery: >50%?
      DRIVERS
      Any driver updates recently, especially GPU?
      MEMORY
      Test your memory overnight with Windows, or Memtest86.
      Also check the “Administrative” section of the event viewer.
      • #1467357
        Hi Super CLiNT,
        Thanks for your time. I’m on the underside of the world from you so sorry for the delay.
        POWER
        I removed the battery after the first crash. It’s been on power only since then probably about a month.
        DRIVERS
        No recent updates. I’m downloading the latest driver now but it comes with this warning.
        ***Important!***
        Please note, that the AMD Catalyst Mobility driver package can only be installed on specific AMD Enduro platforms, that are second generation AMD A-series APU, or third generation Intel Core family based.
        Please note that all other platforms that do not include support for AMD Enduro Technology are supported through AMD Catalyst Mobility.
        I’ve checked memory each time I have used sfc /scannow and Tweaking.com
        I’m hoping this is not as complicated as it seems to be.
        Cheers
        Bob
    • #1467240
      Does the laptop overheat?
      • #1467355
        Hi KritzX
        My laptop always runs a bit hot high of 71-75C but I don’t think it’s over heating. Then again I’m in Jakarta, which is right on the equator and I’m usually working in about 33C.
        Cheers,
        Bob.
      • #1467469
        Usually runs at about 75C but last night when I was doing tests it got up to 85C. Core Temp says 90C is the limit.
      • #1467488
        I’ve just discovered that it does get a bit hot but today it got up to 89 when I was doing a memory diagnostic.
        Do you think that could be the cause?
    • #1467251
      Hi, Bob.
      The bugcheck that triggered the shutdown was a 0x3B, usually a problem with a Windows Service, a driver or graphics driver.
      Do you have any minidumps (C:WindowsMinidump*.dmp)? If you do, copy the last 3-4 to your Desktop, zip and attach them to a reply.
      • #1467353
        Hi, Bob.
        Hi Super Satrow,
        I checked in Minidump and the folder is empty. But I have noticed over the crash period that when I restart and clean with CCleaner that there have been some pretty big minidumps deleted, up around 300 or 400 MB. So should I uncheck minidumps in CCleaner?
        Thanks again.
        Cheers
        Bob.
    • #1467360
      If the dumps are that big, CCleaner is deleting kernel dumps too, turn off CCleaner’s dump cleaning.
      Let’s see what info we can glean without waiting for the next crash, carefully read and follow the instructions here then attach the required zipped folder.
      • #1467364
        Thanks for your prompt reply.
        When my Laptop crashes it doesn’t end with BSOD, it’s just a black screen. When I restart I get the the which restart mode message window 7 normally or Safe Mode. I choose Windows 7 normally without a problem.
    • #1467492
      Possibly, at 89C you’re right up agaist the processor’s thermal wall.
      See if you can increase the fan speed with a software program such as SpeedFan, or a higher fan setting in the BIOS.
      At any rate, you’ll need to keep an eye on it and see if it corresponds to the shutdowns/black screens.
      • #1467608
        Hey Man, Thanks heaps for all your help. I’ve got a heap of work ahead of me from Jared’s recent reply, so hopefully I’ll get to the bottom of the problem in a few days.
    • #1467535
      Also, get a can of compressed air and try blowing out all the vents on your laptop in an attempt to clean any dust accumulation on the processor heatsink/fan assembly. This is not an ideal way to clean it but most laptops have to be completely disassembled to get to the processor.
      Jerry
    • #1467539
      A Kernel Power Event 41 with a BugCheckCode of 59 decodes* to a Bugcheck (aka BSOD, even though no blue screen or memory/minidump was created) 0x3B, in this instance, the BSOD code would read 0x3B (0xc0000005, 0xffff88005175ce8, 0xffff88002be3700, 0x0).
      * http://support.microsoft.com/kb/2028504#method1
      0x3B is usually caused by a Windows Service, a driver or graphics driver, maybe the graphics driver being the most common (perhaps more so in notebooks with dual graphics), it might also be down to a security driver.
      We really need that data from #8 to try to pinpoint the most likely issues.
    • #1467603
      Ok, I see you posted the data over at Sysnative, Bob. I’ve replied there but forgot to ask if you have a C:WindowsMEMORY.DMP file, the log claims to have saved it there?
    • #1467629
      I think it was my post you replied to 😉 , Patrick’s also just stepped in there with a breakdown of the ThermalZone data I dug out of the logs, looks like 100C/212F is too warm for your CPU!
      Event[1018]:
      Log Name: System
      Source: Microsoft-Windows-Kernel-Power
      Date: 2014-09-14T16:31:40.950
      Event ID: 89
      Task: N/A
      Level: Information
      Opcode: Info
      Keyword: N/A
      User: S-1-5-18
      User Name: NT AUTHORITYSYSTEM
      Computer: Bob-PC
      Description:
      ACPI thermal zone ACPIThermalZoneTZS0 has been enumerated.
      _PSV = 371K
      _TC1 = 0
      _TC2 = 50
      _TSP = 0ms
      _AC0 = 0K
      _AC1 = 0K
      _AC2 = 0K
      _AC3 = 0K
      _AC4 = 0K
      _AC5 = 0K
      _AC6 = 0K
      _AC7 = 0K
      _AC8 = 0K
      _AC9 = 0K
      _CRT = 373K
      _HOT = 0K
      _PSL – see event data.
      • #1467638
        Hey thanks Man. Looks like I’ll have to take the thing to pieces and clean it. Either that or leave this big fan on the desk. Which ever way is a pain.
        Cheers
        Bob.
        • #1467732
          Cheers
          Bob.
          Did you try blowing out the vents as I suggested earlier. Disassembling a laptop is a hairy procedure.
          Jerry
          • #1467796
            Jerry
            Thanks for the advice Jerry. Yes I will do everything possible before taking it apart. First up I’ve put my big battery in, that lifts the back of the laptop about an inch off the ground. I checked all the intakes and outlets and they looked okay but it’s difficult to see the CPU fan. I checked Temperature yesterday, not under a big load but it looked good about 63C on idle and 72C under a small load. That’s a lot better than high 80s. I’ll need to buy a trestle table before I can strip it down coz not enough space at the moment. After all the tests looks like an overheat problem. Still checking.
            • #1468972
              Hi Guys, Well I did the dismantle and clean procedure. The day I put it all back together it crashed a couple of times, when left idle. If I remember to put it to sleep before I leave it, it’s ok, doesn’t crash. Please let me know which logs to attach, so we can get to the bottom of this problem. Thanks again for your help.
              Cheers,
              Bob.
            • #1468973
              Temps after cleaning, cooler than 65-85. Off SpeedFan
              HD0: 46C
              Temp1: 51C
              Temp2: 41C
              Core 0: 52C
              Core 1: 50C
              GPU: 59C
    Reply To: Reply #1467360 in Kernel-Power crash problem
