Good day, everyone. I work for the VA – for any veteran or active duty person reading this, thank you for your service. We just upgraded to Office 2007. I have two problems I can’t figure out. First, I had a macro that will reformat text to Courier. I had recorded it in Word 2003 and Outlook 2003 picked it right up. That doesn’t seem to be the case in Outlook 2007. Second, I used Woody’s tip for using Auto Correct to put in often-used phrases or signature blocks. For example, “sgj1” turned into a four line signature block with the first line a different font from the other three. However, when I try to do that, the “use formatted text” radio button is grayed-out. Any ideas? Thanks a lot.
Jim
