• MATCH, INDEX, OFFSET (A2K3)
    Good Morning Everyone,
    I need to Match the column in worksheet2 to a column in worksheet1 then match the row in the worksheet2 to a row in the worksheet1 and index the value in the corresponding column/row of the worksheet1.
    I’m certain I need to apply the MATCH and INDEX and probably the OFFSET but my logic doesn’t appear to be working so well. Here’s what I have so far.
    [indent]
    =IF(ISNUMBER(MATCH(B1,’Sheet2′!B1:C21,0)),INDEX(‘Sheet1′!B2:B22,MATCH(B1,’Sheet2’!A1:A22,0)),0)
    [/indent]
    Can someone please provide me with insight to this? I’m attaching a sample to better explain what I need to do.
    • #1136047
      Hi
      Does the attached does what you want?
      • #1136055
        Yes it does…thank you very much.
        • #1136064
          Thanks for the feedback
          another alternative if you want to use Index…Match as in your original post
          =IF(ISNA(INDEX(Sheet2!B2:B21,MATCH(Sheet1!A2,Sheet2!A2:A21,0))),”no patient”,(INDEX(Sheet2!B2:B21,MATCH(Sheet1!A2,Sheet2!A2:A21,0))))
    Reply To: MATCH, INDEX, OFFSET (A2K3)
