I seem to remember back in the dark days of Networking 101 that there was a maximum number of ethernet switches on the same LAN (or was it segment?).
Our situation is that we have a large Netgear ethernet switch, and connected to it are 25 ethernet cables laid round the floor of the building, each terminating in a socket box at the far end, with a patch cable then going to the PC’s NIC.
Except it isn’t quite as simple as that, as some of the ethernet socket boxes are in the wrong location, and it is necessary to put a small powered Belkin 5-port Network Switch at the end of some of the cables, to give an ethernet connection for up to four PCs at that location.
So my question: is there a maximum number of 5-port Network Switches that can be installed without Unhappiness Occuring? (And no, I am not even thinking of connecting more than 25 of them…!)
(It’s when you have to implement bodges like this that you realise the benefits of flood wiring…)
BATcher
Plethora means a lot to me.
