• MS Project Macro using LinkPredecessors ActiveProject.Tasks
    Home » Forums » AskWoody support » Productivity software by function » Other MS apps » MS Project Macro using LinkPredecessors ActiveProject.Tasks
    Hi,
    I have an MS project Macro which unlink and links predecessors and I get the error 1004 on some project plans but not others, I have compared everything I can think between the plans and all seems similar with no obvious difference.
    Has anybody had this issue or have any ideas as to what could cause it.
    Things I have checked are
    1) The predecessor exists
    2) it is valid
    3) the task has no other constraints
    4) there is no resource conflicts
    5) the links are one to one, so there are no multiple links
    Any ideas/pointers would be appreciated.
    Regards
    Mike
    Reply To: MS Project Macro using LinkPredecessors ActiveProject.Tasks
