I’m not sure where this post should be filed, but lets start here.
I have had Windows 10 for real installed sense last August, the real release and I always install all upgrades as they come.
I also have a windows 7 pro system and it has the same problem.
Sometime in the past couple of weeks the following problem has started.
In my local network I have a Windows 2012 server which I also keep updated. Just server no domain
I keep all my files on that server and have even pointed word and excel to the server folders.
There are a couple of files I use daily so I have shortcuts on my desktop for them.
Example: \filesvrzzzworking projectssome file name.xls
Here is the problem. I can no longer access the “filesvr” via it’s name.
If I use the IP address everything works.
If I use Windows File Manager the same problem, I can get to the Server only by IP address.
Keep in mind that everything was working correctly until a couple of weeks ago.
Networking problem using a server name
- This topic has 3 replies, 2 voices, and was last updated 9 years ago.
AuthorViewing 2 reply threadsAuthorViewing 2 reply threads
