It seems that any equipment you buy today has a big fat plug that covers up plugs on either side of the one it is plugged into. On my APC UPS, what that means is that I don’t have access to all the plugs on the unit.
Is it “OK” to plug a power strip into the UPS so that then I have access to more space so that the plugs will all fit?
I get that I shouldn’t end up have 20 items plugged in through the UPS when the physical plugs available are, say, only four. But what if I plug four devices into a strip and then plug the strip into a unit that has four plugs?
The last time we had an outage, yes my computer kept running, but the mouse and keyboard were both dead since they weren’t plugged into the UPS. It is specifically the keyboard/mouse that I am concerned with, so that at least I can shut down the system properly.
When I looked on the net, I saw no clear determination for this at all.
Regards,
Chuck Billow
Chuck Billow
