I have a PoE problem at (only) two wall-sockets, single box, namely that ordinary ethernet works, but there seems to be no sign of Power-over-Ethernet (as shown by a red light appearing initially on the VoIP phone when it is connected). The only recent change has been a replacement of the cables between the PoE switch and the patch panels. All other wall sockets (about 30) work correctly.
Setup (for each one of the wall sockets is):
[*]HP Procurve PoE switch port [call this point A]
[*]Short patch cable from PoE switch port to Patch Panel port
[*]Cable to the wall socket, perhaps 15m long, in ceiling void
[*]Wall socket port
[*]Patch cable, 5m long, from wall socket port to VoIP phone
[*]VoIP phone’s socket [call this point B]
Actions
[*]I have changed the port on the HP Procurve switch – no good
[*]I have changed the short patch cable from the Procurve switch to the patch panel – no good
[*]I have changed the longer patch cable from the wall socket to the VoIP phone – no good
[*]I have changed the VoIP phone for another one – no good
[*]With a cable continuity tester, I have proved that all 8 pins work on the path from point A to point B
[*]I have connected a laptop to the end of the long patch cable from the wall socket, and can connect to the internet without problems
Theory
“Somehow” the power is being lost, presumably somewhere in the ceiling cable (but why do all 8 pins check out on the cable tester?).
Unfortunately I do NOT have a PoE voltage tester, such as this one.
Can anyone offer any suggestions as to why this is not working? Thanks
BATcher
Plethora means a lot to me.
