• Problem Code (97)
    Worksheet -“Stock” – stores a list of cd’s and their prices.
    Worksheet -“Receipt”- stores a list of cd’s and prices selected from ListBox1.
    Each new selection in any one order is added to the bottom of ranges named Invoice and Invoice2.
    I have written some simple code to achieve this. The problem is that it worked once then subsequently throws up an error on the marked line. The message claims that the object does not support this method or property.
    Private Sub Receipt_Click()
    Dim Invoice, Invoice2, MyCdList As Range
    Dim MyCd As String
    Dim ListBox1 As ListBox
    Worksheets(“Receipt”).Range(“D9”).Select
    x = ActiveCell.CurrentRegion.Rows.Count
    Set Invoice = Worksheets(“Receipt”).Range(“D” & x + 10).Select
    Set Invoice2 = Worksheets(“Receipt”).Range(“E” & x + 10).Select
    Set MyCdList = Worksheets(“Stock”).Range(“A2:A17”)
    MyCd = SelectCd.ListBox1
    MyCdList.Find(MyCd).Select
    Invoice.Value = ActiveCell.Value
    Invoice2.Value = ActiveCell.Offset(0, 3).Value
    Can anyone suggest what the problem is and is there a better way of coding the solution?
    Cheers
    Rob
    • #637811
      I suspect you can do it like this:
      ‘ In your code Invoice and Invoice2 were dimmed as Variant!
      Dim Invoice As Range, Invoice2 As Range, MyCdList As Range
      Dim MyCd As String
      x = Worksheets(“Receipt”).Range(“D9”).CurrentRegion.Rows.Count
      Invoice.Value = ActiveCell.Value ‘Not sure if you need to change this because the activecell might have changed!
      Note I removed all selecting, since that is not necesary.
      • #637815
        Many thanks, Jan Karel.
        Would you explain the cause of the error message?
        Cheers
        Rob
        • #637827
          Because the sheet you are trying to select a cell on is not the active sheet. To avoid that problem, first select the sheet:
          Worksheets(“WhateverSheet”).select
          Activesheet.Range(“C3”).Select
          Or use:
          Application.goto Worksheets(“WhatEverSheet”).Range(“C3”)
    Reply To: Problem Code (97)
