• Problem registering in Forums w/FF28?
    Home » Forums » AskWoody support » Questions: Browsers and desktop software » Other browsers » Problem registering in Forums w/FF28?
    Hi,
    RE: Problem registering in Forums w/FF28?
    I don’t know how many forums I’ve registered in since I’ve been using FF browser. Many in 10 yr?
    Currently I’ve registered in 3 separate forms, registration went fine, responded to confirm email when appropriate.
    However when I later go back to the forum, log-in was denied? When possible, I contacted the forum about my log-in problem.
    One forum responded twice with a password reset to no avail. Others haven’t responded yet.
    “Me thinks something is rotten in the state Denmark”
    Note: I was able to get into this forum with no problem and others I have already signed up for.
    cheers,
    klx
    Viewing 5 reply threads
    • #1472658
      Have you tried those forums with IE – and FF is up to v33.01 now unless you’ve reverted to v28.0 for other reasons ?
      • #1472663
        Hi,
        Just tried to log with IE 11 at forum that would not accept my log in & got this.
        FF33 was too minimalist for me.
        Thanks,
        klx
        • #1472668
          That’s a problem with the website and for the forum’s admins to sort out but if you aren’t getting any replies from them….
          You could try adding a couple or so numbers to your username and open a spare http://www.gmail.com account to see if they stick.
          • #1472669
            Thanks,
            I’ll give it a try; however I don’t use web mail, esp Google because past breaches of security, privacy that cost me dearly.
            How could basic forum registration not work after 25 yrs of use on the net? This is 2014, and with the best n’ brightest running things, this simple operation should be ubiquitous.
            Your forum works fine & I have a 15 yr old Mazda Protege that runs like a top & gets good gas mileage.
            Hope we don’t have to put a “Man on the Moon, 1968” and return him safely.
            cheers,
            klx
            • #1472670
              Well maybe we’ll get it right next year…like putting a man on the moon on July 20, 1969! 35623-ROTFLOL
            • #1472682
              Thanks,
              cheers,
              klx
              The e-mail address is probably more for reply notifications as it is for this forum so you don’t need to use it for anything else.
              @ RG – I was stationed in Germany and on guard duty that night and watched the pics on a small black and white portable tv someone had brought into the Guard Room – Happy days 🙂
            • #1482908
              because they keep making changes
              to force us to buy new hardware and software
              at some point compatibility no longer is compatible
              and things stop working unless you cave and upgrade
              Thanks,
              cheers,
              klx
        • #1472720
          Hi,
          Thanks,
          klx
          Surely that image is one where you’re trying to register not login – so it would show as already being in use – or have I missed something there?
          In what way is FF ‘minimalist’?
          • #1481450
            access mdb
            I did upgrade to FF 34 by accident, FF28 crashed, wouldn’t open at all. Then after a zillion, try’s, re-boots, web searching, it finally “opened”. Then it automatically updated to FF 34 after removing & saving my FF 28 stuff.
            FF 34 did work but the items on the menu/tool bars were hidden or in the wrong place. After messing around with FF34 I was able to restore some “catywampus” order. I need modify [and can] most of my tool/menu bars for decades because of my vision situation.
            I finally came up with a tool bar config I can “almost” work with; however some changes have to be made yet, see red arrows on image below:
            Red arrows indicate the positions I need buttons to be inserted.
            Is there a way to position buttons in that manner” Image way below:
            [/B]
            I just installed the Classic Toolbar Buttons 1.4.5 & Theme restorer 1.2.82 ad-ons in FF 34; however Classic Toolbar Buttons 1.4.5 is useless unless I can see what the descriptions of the changes look like. This is one of the ‘minimalist’ problems I was talking about.
            Old Fred R. Barnard in 1913 knew the importance of seeing what you are getting. Image way below.
            If you know where I view actual images what the “changes” would look like, I’d appreciate if you could point me in the right direction.
            If I can solve my tool bar situation with these 2 ad-ons I’ll do that; however I’ll need some visuals.
            [INDENT][INDENT]Classic Toolbar Buttons Classic toolbar button style for Firefox, Thunderbird and Seamonkey toolbars and other tweaks and settings.Toolbar buttons gui was changed for “small icon view” in Firefox 8, “large icon view” in Firefox 14 as well as for Thunderbird 15. The Windows only add-on “Classic Toolbar Buttons” restores the old buttons gui for toolbar buttons on navigation toolbar, main toolbars (Thunderbird/Seamonkey) and also makes it optionally available for toolbar buttons placed on other toolbars like menu-, tabs-, bookmarks- or add-ons toolbars. Some basic tweaks are also available for Thunderbird and Seamonkey.
            Features & Options for Firefox
            classic toolbar buttons style for …
            … toolbar buttons on menu toolbar
            … toolbar buttons on tabs toolbar
            … toolbar buttons on navigation toolbar
            … toolbar buttons on bookmarks toolbar
            … items and folders on bookmarks toolbar
            … toolbar buttons on add-ons toolbar
            … toolbar buttons on All-In-On-Sidebar
            … toolbar buttons on library toolbar
            … tab-scollbuttons (if visible)
            … “back-forward-dropmarker” (if installed/enabled)
            toolbar button icon settings
            default (let Firefox or a theme or a third party add-on decide)
            Firefox 1
            Firefox 2
            Firefox 3
            Firefox 3 (Strata)
            Firefox 4-12 (dark)
            Firefox 4-12 (white)
            Firefox 13+ (dark)
            Firefox 13+ (white)
            Firefox Ubuntu (thx to Bollerkopp & Tango Desktop Project)
            Firefox MacOSX
            Seamonkey
            Firefox (Mozilla mix)
            Noia
            download button indicator icon settings
            default downloads toolbar icon (always)
            green arrow (Firefox default)
            blue arrow
            toolbar button dropmarker icon settings
            default (let Firefox or a third party add-on decide)
            dark & small icon
            dark & big icon
            white & small icon
            white & big icon
            back-forward button settings
            Firefox 3 (green)
            Firefox 3 (Strata blue)
            Firefox 3 (Strata blue v2)
            Firefox 3 (red)
            Firefox 3 (orange)
            Internet Explorer 8
            Internet Explorer 9
            reload-stop-go button gui (if button on urlbar)
            classic style (Firefox 4-8)
            Australis style
            classic downloads window
            restore hidden forward-button (if connected to urlbar)
            restore classic green & blue identity-box colors
            change toolbar buttons border radius
            change toolbar buttons height/width
            change spaces around and between toolbar buttons
            Features & Options for Thunderbird
            … toolbar buttons on main toolbars
            default (let Thunderbird or a theme or a third party add-on decide)
            Thunderbird (dark)
            Thunderbird (white)
            Thunderbird 1
            Thunderbird 2
            Thunderbird 3
            Thunderbird 3 (Strata)
            Thunderbird (MacOSX)
            default (let Thunderbird or a third party add-on decide)
            dark & small icon
            dark & big icon
            white & small icon
            white & big icon
            Features & Options for Seamonkey
            … toolbar buttons on main toolbars (browser, mail, composer, adressbook, editor, Lightning)
            default (let Seamonkey or a theme or a third party add-on decide)
            Firefox 1
            Firefox 2
            Firefox 3
            Firefox 3 (Strata)
            Firefox 4-12 (dark)
            Firefox 13+ (dark)
            Firefox 13+ (white)
            Firefox MacOSX
            Noia
            Thunderbird (dark)
            Thunderbird (white)
            Thunderbird 1
            Thunderbird 2
            Thunderbird 3
            default (let Seamonkey or a third party add-on decide)
            dark & small icon
            dark & big icon
            white & small icon
            white & big icon
            Notes
            All settings are for the default theme, but they “may” work with other themes and toolbar-styling add-ons too, like L.A.R Grizzlys themes, Statini Super theme, Strata M4 theme, Tangerinefox theme and maybe others!
            Firefox / Thunderbird / Seamonkey
            Firefox settings are only visible on Firefox
            Thunderbird settings are only visible on Thunderbird
            Seamonkey settings are only visible on Seamonkey
            “Add-on Compatibility Reporter” add-on
            If you have problems or find bugs, please contact me by email (provided inside my profile) or use this add-ons support page. Sending (false) reports using “Add-on compatibility Reporter”-extension without a proper description are not valid and cannot be fixed![/INDENT][/INDENT]
      • #1482907
        i had one site that wanted an older version of ff
        when i downloaded i got 33 instead of 2x and it totally forked my pc and did not run
        cant get rid of it either
        so stuck using chrome now
    • #1472717
      Thanks guys,
      I’ll create a workaround.
      38257-box-and-dot-image-for-doc
      cheers, klx
    • #1481483
      klxdrt, this is my FF34 with arrows pointing to those things you wanted.38814-ff34. You can probably get them by right clicking on a toolbar and choosing customize. Actually the one between the address and the search, just hover over the gap and you should be able to adjust the width of them by moving left or right.
      Is this what you mean?
      • #1481590
        access mdb,
        Below is a pix of my ff34 tool bar after your advice applied. I can live with that layout, however I’m looking for a way to swap positions of the “search field” with the “address field”
        & add some color to the rest of the hard to see gray buttons.
        I appreciate your continued assistance.
        cheers,
        klx
    • #1481551
      Are you running Malwarebytes Anti-Exploit? If so, disable the shield for your browsers. If not, I’ll listen in and learn from the others. I had a similar problem and the every-eternal circle problem until I disabled the MBAE browser shields.
      • #1481588
        Roland,
        Thanks for joining in “the more the merrier” especially around the holidays. [Are you running Malwarebytes Anti-Exploit? NO]. As of now all is A-OK. But things change.
        cheers,
        klx
    • #1481593
      klx, if you go to customise again, hover over the search box (which should be in a dotted box), the cursor changes to a hand. Left click and move it to where you want. You can experiment to see if you can move other things. To change colour may have to download a suitable theme (got from tools/addons/appearance).
      p.s. you didn’t include your pic of the results as you said you would…..
      • #1481624
        Thanks, I was able to swap the fields this time, but it took a lot of moving the cursor around until it changed into a hand for moving.
        Also, just checked & pic is there.
        cheers,
        klx
        • #1481885
          cheers,
          klx
          finally found a theme/buttons that works
          klx
    • #1481990
      Glad you found a suitable solution.
    Reply To: Problem registering in Forums w/FF28?
