• Problem with QRY statement
    I’m having trouble with the following statement:
    CurrentDb.Execute “INSERT INTO tblOT SELECT tblOTemp.* FROM tblOTemp”
    The attached pic shows that tblOTemp has 13 records in it but tblOT behind it shows that only 6 (in this case) have been copied over.
    Any Ideas anyone? On other occasions I have had all, 1, 2, 4 records copied over but it should be a consistent 13 (employees).
    • #1281485
      The failures result probably because the OTID value in those inserted records already exist and I presume OTID is unique.
      CR
    Reply To: Problem with QRY statement
