I am having problems debugging a subroutine that I have inserted into a macro. I have used this subroutine many times before in different situations to fill down values or formulas, but for some reason when I inserted it into this macro it is giving a run-time 1004 error. Any help would be appreciated. I have attached a stripped down version of the spreadsheet and macro.
problems with subroutine (2007)
Home » Forums » AskWoody support » Productivity software by function » MS Excel and spreadsheet help » problems with subroutine (2007)
- This topic has 3 replies, 3 voices, and was last updated 16 years, 9 months ago.
AuthorTopicWSgvanhook
AskWoody LoungerSeptember 2, 2008 at 6:32 am #453647Viewing 1 reply threadAuthorReplies-
WSHansV
WSgvanhook
AskWoody LoungerSeptember 2, 2008 at 7:01 am #1124183Hans, As soon as you sent the answer I realized that my friend was still using 2003. I should have realized that was the problem but I didn’t check the file extension. Thank you again for all of your help. The new version of this subroutine that you suggest will allow it to work in both versions.
WSfranciz
AskWoody LoungerSeptember 2, 2008 at 6:53 am #1124181Not sure if you are using 2007 version but I try it in 2003 version.
I believe the line that cause the error is ” lLastRow = Cells(999999, iCol).End(xlUp).Row ”
change it to “65536” instead if you are using versions other than 2007.Note: can’t help on 2007 version as I don’t have a copy of that.
regards, francis
Viewing 1 reply thread -
Move OneNote Notebook OFF OneDrive and make it local
1 hour, 10 minutes ago -
Microsoft 365 to block file access via legacy auth protocols by default
2 hours, 28 minutes ago -
Is your battery draining?
1 hour, 53 minutes ago -
The 16-billion-record data breach that no one’s ever heard of
4 hours, 26 minutes ago -
Weasel Words Rule Too Many Data Breach Notifications
5 hours, 1 minute ago -
Windows Command Prompt and Powershell will not open as Administrator
Gordski
8 hours, 16 minutes ago -
Intel Management Engine (Intel ME) Security Issue
PL1
11 hours, 13 minutes ago -
Old Geek Forced to Update. Buy a Win 11 PC? Yikes! How do I cope?
RonE22
1 hour, 31 minutes ago -
National scam day
macOS Tahoe 26 the end of the road for Intel Macs, OCLP, Hackintosh
1 hour, 42 minutes ago -
Cyberattack on some Washington Post journalists’ email accounts
Bob99
Tools to support internet discussions
How get Group Policy to allow specific Driver to download?
21 hours, 11 minutes ago -
AI is good sometimes
Mozilla quietly tests Perplexity AI as a New Firefox Search Option
Perplexity Pro free for 12 mos for Samsung Galaxy phones
Patricia Grace
2 days, 13 hours ago -
June KB5060842 update broke DHCP server service
2 days, 12 hours ago -
AMD Ryzen™ Chipset Driver Release Notes 7.06.02.123
2 days, 16 hours ago -
Excessive security alerts
WSSebastian42
* CrystalDiskMark may shorten SSD/USB Memory life
3 days, 1 hour ago -
Ben’s excellent adventure with Linux
Ben Myers
18 hours, 45 minutes ago -
Seconds are back in Windows 10!
WebBrowserPassView — Take inventory of your stored passwords
OS news from WWDC 2025
16 hours, 29 minutes ago -
Need help with graphics…
WSBatBytes
AMD : Out of Bounds (OOB) read vulnerability in TPM 2.0 CVE-2025-2884
3 days, 17 hours ago -
Totally remove or disable BitLocker
Windows 10 gets 6 years of ESU?
n0ads
2 days, 19 hours ago -
Apple, Google stores still offer China-based VPNs, report says
4 days, 3 hours ago -
Search Forums only bring up my posts?
Deo
