• Reset printer to default using VBA (Word 2000)
    Home » Forums » AskWoody support » Productivity software by function » Visual Basic for Applications » Reset printer to default using VBA (Word 2000)
    The situation: A user has printed something to a printer (I’ll call it Print2) *other* than their default printer (Print1). Word retains the Print2 as the active printer until the user switches back.
    I need to create a button that will set the active printer back to the default printer. The default printer is not the same for all users, I can’t hardcode that–I essentially need something that sets the active printer to the default printer.
    Why can’t users just change this themselves? I do not know. Apparently they are too well paid to be expected to understand how to check their printer settings. (Grr. Sorry. Just venting.)
    In any event, any thoughts would be appreciated….thanks.
    Jen
    • #559263
      Well, this isn’t as well documented as you might think. Here’s the answer if you’re a C programmer
    • #559278
      I had a similar problem in a project that I am developing – I needed to switch to a different printer before opening Crystal reports (which picks up the default printer and doesn’t let you change before printing!).
      Couple of functions here might help…
      ‘ // To notify applications the printer has changed
      Private Const HWND_BROADCAST As Long = &HFFFF
      Private Const WM_WININICHANGE As Long = &H1A
      Private Declare Function GetProfileString Lib “kernel32” _
      Alias “GetProfileStringA” _
      (ByVal lpAppName As String, _
      ByVal lpKeyName As String, _
      ByVal lpDefault As String, _
      ByVal lpReturnedString As String, _
      ByVal nSize As Long) As Long
      Private Declare Function WriteProfileString Lib “kernel32” _
      Alias “WriteProfileStringA” _
      (ByVal lpszSection As String, _
      ByVal lpszKeyName As String, _
      ByVal lpszString As String) As Long
      Private Declare Function SendMessage Lib “user32” _
      Alias “SendMessageA” _
      (ByVal hwnd As Long, _
      ByVal wMsg As Long, _
      ByVal wParam As Long, _
      lparam As Any) As Long
      ‘ // FUNCTION
      ‘ // SubDefaultPrinter(ByVal PrinterName As String,
      ‘ // ByVal DriverName As String,
      ‘ // ByVal PrinterPort As String)
      ‘ // PARAMETERS
      ‘ // PrinterName – The name of the object printer
      ‘ // Drivername – The name of the driver for the objet printer
      ‘ // PrinterPort – The name of the port to action the printer on
      ‘ // RETURN VALUE
      ‘ // None
      ‘ // COMPONENTS USED
      ‘ // Windows Registry
      ‘ // NOTES
      ‘ // You can change the ‘default’ printer programatically by using the Win32-API. Used
      ‘ // to switch from a default printer to ‘Zetafax’ without any user interction
      Private Sub SetDefaultPrinter(ByVal PrinterName As String, _
      ByVal DriverName As String, _
      Dim DeviceLine As String
      ‘rebuild a valid device line string
      DeviceLine = PrinterName & “,” & DriverName & “,” & PrinterPort
      ‘Store the new printer information in the
      ‘[WINDOWS] section of the WIN.INI file for
      ‘the DEVICE= item
      Call WriteProfileString(“windows”, “Device”, DeviceLine)
      ‘Cause all applications to reload the INI file
      Call SendMessage(HWND_BROADCAST, WM_WININICHANGE, 0, ByVal “windows”)
      ‘ // FUNCTION
      ‘ // GetDefaultPrinter()
      ‘ // PARAMETERS
      ‘ // None
      ‘ // RETURN VALUE
      ‘ // String representation of the current default printer
      ‘ // NOTES
      ‘ // Returns the value held in the registry that represents the users default printer
      Public Function GetDefaultPrinter() As String
      Dim sReturnString As String
      ‘ // Allocate string space
      sReturnString = Space(1024)
      ‘ // Get the currently active (default) printer held in the registry
      GetDefaultPrinter = Left(sReturnString, GetProfileString(“windows”, “Device”, “”, sReturnString, Len(sReturnString)))
      ‘ // Cause all applications to reload the INI file
      End Function
      Test out the ‘GetDefaultPrinter’ function which should return the print string that is stashed in the registry
      • #559288
        jscher2000 and Dylan Morley: Thanks for your thoughts. I shall give both of these options a try and let you know what I figure out.
        I’m surprised that it isn’t easier, though…like a .defaultprinter setting as compared to a .activeprinter setting, or something like that.
      • #559307
        Edited by klyjen on 20-Dec-01 13:28.
        Dylan–that did it! Thanks! I used your code, and then added a “ReSetDefaultMacro sub that looks like this…I had to do that because these are network printers and returning the string as your function returned it couldn’t be read by the application.activeprinter setting.
        Public Sub ReSetDefaultPrinter()
        Dim sDefaultPrinter As String
        Dim First
        Dim Last
        Dim Total
        Dim PrinterName
        Dim PrinterEnd
        Dim counter As Integer
        ‘runs the GetDefaultPrinter function (above) and returns the value
        ‘into a string called sDefaultPrinter–this returns a string that
        ‘looks like (DC-7B1,winspool,NE74 smile
        sDefaultPrinter = GetDefaultPrinter()
        ‘clears the active printer
        Application.ActivePrinter = “”
        ‘determines the position of the first comma in the string
        First = InStr(1, sDefaultPrinter, “,”)
        ‘determines the position of the last comma in the string
        Last = InStrRev(sDefaultPrinter, “,”)
        ‘determines the total length of the string
        Total = Len(sDefaultPrinter)
        ‘determines the printer name (the characters up to the first
        ‘comma in the string)
        PrinterName = Left(sDefaultPrinter, First – 1)
        ‘determines the code at the end of the string)
        PrinterEnd = Right(sDefaultPrinter, Total – Last)
        ‘resets the active printer to the default, setting the string to
        ‘look like it should (i.e., “DC-7B1 on NE74:”)
        Application.ActivePrinter = PrinterName & ” on ” & PrinterEnd
        ‘creates a message box letting the user know the printer has
        ‘been reset and what its value is now
        response = MsgBox((“Your printer has been reset to ” & PrinterName & “.”), vbOKOnly)
        Thanks very much for your help. I will definitely keep your code for future use!
        Jen
        EDIT: That shouldn’t be a smiley, it should be a : followed by a ) I can’t figure out how to turn off the smileys in here!
    Reply To: Reset printer to default using VBA (Word 2000)
