• Same Problem but more
    Hi I hope your still around
    I get the following error after booting the SSD after following your instructions see attachment
    Viewing 6 reply threads
    • #1467255
      Stimps,
      Welcome to the Lounge as a new poster. :cheers:
      I moved your post to it’s own thread rather than have it at the end of an old thread.
      Could you please provide more information.
      Did you restore an image from the same machine, e.g. just going from HDD to SDD on same hardware? Or did you try to restore an image from some other hardware specifically one w/o UEFI/Secure boot?
      Did you copy ALL of the partitions to the new drive saving the C: for last?
      :cheers:
      • #1467267
        Glad your still here !
        I just followed your instructions Cloned all the partions except c then copied c drive
        Stimps
    • #1467273
      Stimps,
      You say you “Cloned” them? Do you really mean Clone or did you do an Image backup, they are different.
      If you didn’t do an Image I’d suggest replacing the HDD and doing a complete drive Image.
      Then replace the SSD and follow the instructions again booting from the MR Windows PE recovery disk. HTH :cheers:
      • #1467305
        Stimps,
        I followed your instuctions as i said Clone first then copy
        • #1467318
          Mike,
          I said:
          I don’t know about the options for cloning but I did restore the image I took of my 1 TB HDD to a 128Gb SDD by using the features in Macrium to resize the OS partition (C down to fit on the SSD. It was very easy. I first copied/restored all the other partitions then sized the [noparse]C:[/noparse] to fit in the remaining space. Here’s what it looks like now.
          So as I said previously, Reinstall the original HDD, Image it, then restore to the SSD. HTH :cheers:
          • #1467397
            Mike,
            Opps sorry just reread the thread and you didn’t use clone the other guy did
            So I just use copy no cloning involved?
            Should I reformat my SSD drive before I start again ? Will a quick format suffice ?
            Thx Stimps
    • #1467280
      I’ve come across that message before. It usually means that the software you used didn’t successfully modify the clone to run on an SSD. I now use DriveClone, which makes the necessary changes and therefore the SSD boots without any modification. Ignore the fractured English on the web site, its a Taiwanese company. Two things to bear in mind. 1/ When you start it, it may throw up a couple of errors. Click through them and it will run without any problems. 2/ Go into Advanced on the menu screen and deselect Smart Cloning if you have any cookies you don’t want to be left behind.
      http://www.farstone.com/software/drive-clone.php
      Always check for bundled unwanted extras when downloading and installing any new software and be sure to decline them. Use custom install when it’s available
      • #1467398
        Thanks for that are you sure clicking through errors is safe ?
        What do you think of this program RetiredGeek ?
    • #1467311
      Stimps,
      Exactly which Instructions? :cheers:
      • #1467313
        Stimps,
        Exactly the instructions you gave in the last old thread
        Mike
    • #1467399
      Mike,
      If you take an Image (see post #4 above) of the HDD there is no need to reformat the SSD, which would only use up some of its limited write cycles. HTH :cheers:
    • #1467406
      Limited write cycles?
      • #1467437
        It means that an SSD is quite similar to a pen drive or memory card. You can only write stuff to an SSD and delete them, a limited number of times, after which, the SSD will wear out (similar to a flash drive or memory card). Therefore, you must be careful to ensure that you don’t wear out the SSD too soon, by writing unnecessary data to it.
    • #1467500
      Thanks so much everyone all fixed now man this is fast
    Reply To: Same Problem but more
