• Seagate hard drive problems
    If any of you are running with Seagate hard drives, you may want to check out this article.
    Potential timebomb.
    Cheers, Bob
    • #1142290
      Thanks for posting this, Bob. I just bought one of the affected drives last week. Where/how did you learn about this?
      Cheers,
    • #1142338
      I have a couple of FreeAgent external drives, and it’s quite difficult to determine the model number of the drive that resides inside the case. Perhaps it isn’t necessary?
      One thing about that page: the embedded document is hard to read in Firefox. One can enlarge the iframe and add a vertical scroll bar using this bookmarklet (paste into address bar above the page and press Enter to run the script):
      java script:idoc=document.getElementsByTagName("iframe")[0];idoc.style.width="100%";idoc.style.height="400px";idoc.style.overflow="auto";void 0;
      Note: that is all one line.
      Added: As far as I can tell, the FreeAgent family of drives does not require an update.
      • #1142343
        >> ….the embedded document is hard to read in Firefox…
        Did you enable scripting for kustkb.com? – it seems quite readable if you do! smile
      • #1142346
        I just recently installed Firefox 3.0.5 and can read the entire page without a problem. Which “embedded document” are you referencing?
        WRT your Free Agent drive(s)… have you tried downloading the Seagate tool to see if that id’s the FA Seagate drive model number?
        Cheers, Bob
        • #1142366
          It is a problem with the FireFox NoScript addon. If you use FireFox without this addon then you would not see the problem.
          StuartR
          • #1142414
            Thanks Stuart.
            Running Firefox for the first time… no add-ons so far.
            Thanks again…
            Cheers, Bob
            • #1142421
              A Habs/Als fanboy who lives in Leafs/Argos territory, and uses FF!!! There is intelligent life down there! grin
              Cheers,
            • #1142426
              jollyroger
              Born and raised in Montréal.
              Left the province in 1979 as part of the financial industry sneaking out of Québec heading west along the 401 to greener pastures.
              Was, and still am, a Habs/Als fan. When I have been in the GTA for as long as I lived in Montréal, which will be around the year 2018, I might consider switching allegiances. Nah, I lie… tain’t no life pulling for the Leafs or Argos!!! toilet grin
              As for FF… just putting her to the test. So far, so good. munch
              jollyroger
              Cheers, Bob
    Reply To: Seagate hard drive problems
