• sound when changing web pages (7)
    I recently uipgraded to IE7. Now every time a change webpages my computer makes a noise. I would like to trun that off and can not find where to do so.
    • #1088217
      Try this: Control Panel > Sounds… Start navigation or Complete navigation are the ones I think.
      (As they say, one picture is worth a thousand clicks…)
      • #1088221
        No. That was already off like it is in your illustration.
        This noise is in Internet Explorere, not Windows Explorer.
        • #1088222
          Yep – turning off both navigation sounds applies in IE for me.
          (You did turn off both Start and Complete navigation sounds? And the Blocked Pop-up window, and Information bar…?)
          • #1088423
            It was the information bar that was making the sound.
            Thanks for the help, Leif
        • #1088236
          You can always set them as I did.
    Reply To: sound when changing web pages (7)
