How do I troubleshoot an audio problem? Occasionally there is a constant hissing/buzzing from the speakers – how do I go about isolating this?
troubleshoot audio problem
Home » Forums » AskWoody support » Windows » Windows Vista, XP and earlier » Questions: Vista, XP back to 3.1 » troubleshoot audio problem
- This topic has 5 replies, 2 voices, and was last updated 24 years, 4 months ago.
Viewing 0 reply threadsAuthorReplies-
WSLeif
AskWoody LoungerDecember 31, 2000 at 10:01 am #508667Does it stop if you mute from the screen volume control?
It sounds more like a bad connection. From the volume control, showing all inputs, try muting each input in turn which may isolate an input problem.
Otherwise, it may be the plugs to your speakers – just twiddling them can show up a dirty contact. -
WSmdc
WSLeif
WSmdc
WSLeif
AskWoody LoungerDecember 31, 2000 at 4:11 pm #508679I don’t honestly know. I suspect that it may be a hardware problem – but where do you start? You could check things like the card is properly seated in its slot – even taking it out and refitting may help.
Make sure the screw fixing the card bracket to the chassis is secure.
Other than that, it may just be the age of the card.
Can you not just get away with leaving it muted?
Viewing 0 reply threads -
dmt_3904
2 hours, 27 minutes ago -
Login screen icon
7 hours, 33 minutes ago -
AI coming to everything
3 hours, 41 minutes ago -
15 hours, 1 minute ago -
No Screen TurnOff???
15 hours, 23 minutes ago -
BigDaddy07
15 hours, 56 minutes ago -
n0ads
13 hours, 50 minutes ago -
You can’t handle me
1 hour, 23 minutes ago -
6 hours, 27 minutes ago -
18 hours, 25 minutes ago -
Lumma malware takedown
EyesOnWindows
2 days ago -
2 days ago -
Meet Gemini in Chrome
2 days, 4 hours ago -
Trump signs Take It Down Act
2 days, 12 hours ago -
16 hours, 59 minutes ago -
not so anon
2 days, 15 hours ago -
2 hours, 48 minutes ago -
hibernate activation
e_belmont
3 days ago -
3 days, 4 hours ago -
3 days, 7 hours ago -
2 days, 3 hours ago -
Out of band for Windows 10
3 days, 12 hours ago
